My rear subframe refurbishment
Old 05-16-2015, 06:07 AM
scoobie's Avatar
Before and after -
Don B (08-06-2015)
  #62
Old 05-16-2015, 06:28 AM
scoobie's Avatar
Originally Posted by daro31
I bought my 2004 XK8 last november and over the winter did the best I could do on the bottom with POR15. The underbody is good and solid with no invasive corrosion but the rear suspension pack is pretty rusted. I did the best I could to clean up the surface rust and protect exposed areas until I have next winter to go at the rear end. I am up here in Canada and I suspect this car may have seena little road salt in its lifetime. I work in the auto parts business and one of my suppliers does Zinc Plating for us. He said when you get the parts all off let me have em and hewill run them through his derusting solutions ans zinc plate everythign for me. I know I am the only one that will see it, but I think that will look pretty sharp. I will continue to follow your project with interest.
Daro,
If you can get the subframe and other parts galvanised it will be far far better than what I have done using paint.
A friend had his series II landrover bulkhead stripped and galvanised and from memory it was very expensive but should last almost forever.
What he didn't take account of however was how much all of the holes decreased in size due the the plating being thicker at ends of the metal than in the middle.
Good luck with your project
  #63
Old 05-17-2015, 12:49 PM
scoobie's Avatar
Bolted back in place - can't believe this took me 5 months (better stick to the day job )
Next - refurbish and paint rear brake calipers.
oyster (12-16-2015)
  #64
Old 05-17-2015, 01:47 PM
RaceDiagnostics's Avatar
Well done, great job, 5 months later and I still haven't got round to starting yet.
  #65
Old 05-17-2015, 01:58 PM
Received 4,280 Likes on 3,700 Posts
nicely done
  #66
Old 07-17-2015, 11:00 AM
LONERANGER's Avatar
Default How to remove rear end supension .
can't find link .
  #67
Old 07-17-2015, 12:08 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
Welcome to the forum. The procedure is in the JTIS21 factory manual which can be downloaded from the Sticky near the top of the forum page.
When you have time please visit the new member area and introduce yourself and your car:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
  #68
Old 07-17-2015, 08:58 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
All I can say is WOW!
  #69
Old 12-16-2015, 02:27 PM
stephensd1's Avatar
hi any idea were I can get part number 3 on the Above drawing please.
part no. MJA3701AA (left side)
Right side also required.
part no. MJA3700AA
no longer available from jaguar
steve,
stephendsd1@sky.com
07940261117
  #70
Old 12-16-2015, 02:45 PM
  #71
Old 12-16-2015, 03:23 PM
stephensd1's Avatar
Hi,
thank you I did phone them but got no reply I will try again tomorrow
many thanks.
steve.
  #72
Old 12-16-2015, 05:29 PM
stephensd1's Avatar
hope I can get mine to look as good
well done mate
  #73
Old 01-18-2021, 09:07 AM
chris-jag's Avatar
Originally Posted by scoobie
What size are these nuts holding the driveshaft to diff?
They are bigger than 17mm but much smaller than 18mm - are they some weird A/F or other size?
As an fyi, these threads are imperial 7/16 unf on the x308 differential, so maybe the same on yours? Gives you something to start on at least.
Don B (01-18-2021)
  #74
Old 12-10-2022, 09:23 AM
St. Stephen's Avatar
Hi, I'm about to start doing this job too. You mentioned whislt disassembing, your only regret wasnot marking the camber. What is the lower fulcrum shaft pin, where is it and how do I mark the camber please?
  #75
Old 12-10-2022, 10:33 AM
michaelh's Avatar
Received 2,381 Likes on 1,545 Posts
See this pic pinched from GordoGatCar's incredibly clean machine:
The head of the lower fulcrum bolt (Jaguar calls it an 'outer pivot pin') circled in red. There is a tiny arrow on the eccentric circumference which you can line up with a witness mark you need to make on the lower control arm, or you can roll your own pointers. Be careful that you don't lose the marks if you paint the arm,etc., and watch out for the spacers between the arm and the hub carrier.
The following 3 users liked this post by michaelh:
Don B (12-10-2022), St. Stephen (12-10-2022), toaster (05-27-2024)
  #76
Old 12-10-2022, 11:02 AM
Thank you MichaelH. God Bless.
scoobie
11-01-2023 03:02 PM
WinterJag
01-09-2016 04:41 PM
Brake buster
03-25-2015 02:45 AM
kreyszig
02-03-2014 08:22 AM
Nos_Monkeys
05-04-2013 09:42 PM
Quick Reply: My rear subframe refurbishment
