My sick cat
Greeting,
I have just picked up (about a month ago) a 2000 XK8 convertible with 65 k miles. For the first 2 weeks it was a dream to drive, everything worked great.
Since then, my check engine light has come on and it runs rough with the "Restricted Performance" illuminated. I put a scanner on it and it said I have a miss fire in cylinder two. Since I just got it i figured I would change all the coil packs and plugs since this happened with my BMW 740 Li. Did all the work with no results.
Any Ideas or suggestions would be greatly appreciated!!!
Greeting,
Second on this forum you can download a copy of the Workshop Manual and with your OBD codes the manual will take you step by step to diagnose the problem for the specific code.
Good luck.
sickcat (06-23-2022)
I put in new coil packs and new platinum plugs, it's a 2000 with 65000 miles, got it from an estate sale with tons of receipts and records of maintenance, big reason why I'm baffled
The following 3 users liked this post by dibbit:
The following 2 users liked this post by Kev-P-:
David Dougherty (06-15-2022),
sickcat (06-15-2022)
Yes! The DTC you are seeing would help a lot.
I'm starting to think making (fairly major) changes to these unsupecting cars can cause them to have a tizzy. What kind of coil packs did you use...? And please tell me you saved the old (original) ones....? And plugs and gap (double check plug gap out of the box)...
With a lot of bumps on the head I'm learning (kinda) that these cars don't like hard changes like new looms to the ignition system, new coil packs, plugs etc - because something was going wrong with the originals - and a bunch of new parts get thrown.
After swapping everything. Did you try a hard reset of the cars systems? Might help. I do hard resets by disconnecting the battery, clipping the 2 leads together, then switching the key to the run position and leaving it for a long while. Then, returning the key to OFF, reconnecting the battery and trying again. I'll first clear ALL codes on first start,,, then see what happens.
Received 1,684 Likes
First off, I have to admit I’m down with the OCD crowd, as long as the behavior doesn’t hurt anyone else.
That said, I use a 20 oz bottle of Techron Full fuel system cleaner every 3rd tank of gas , which is about 1 every 1,000 miles. I have a 2002 4.0 XKR, with 177,000 miles on it and the injectors have never been serviced . The supercharger has to come off to do the job and I just want to put that off as long as possible.
Using that much Techron does not seem to have had any negative consequences (besides the cost), since I’ve been doing it for 3.5 years.
I also have other OCD XKR behaviors, like keeping the car on a battery tender whenever it’s not being driven overnight or longer.
Plus the OCD of opening the hood (bonnet) when the car in back in the garage after a hot drive. Heat soak will shorten the life of the cooling hoses (some of which are also under the supercharger) and mine have never been changed. Would like them to last another 5 years at least.
My car is a daily driver with about 15,000-20,000 miles logged every year. So far it’s been more dependable than any other 20 year old car I’ve owned.
Z
The following 4 users liked this post by sickcat:
dantheman1
12-15-2020 05:01 PM
Christopher Robert Lowndes
07-02-2015 05:19 PM
