My turn to ask for help! - RESOLVED
I removed the top hydraulic latch to send it out for reseal. Reinstalled last night and refit the overhead bits and tested the top and latch with no issues. Then I plugged in the connections for the overhead console and the sun visors. Put the key in to start the engine and the steering wheel went weird. Went to full aft and full down and started to twitch to and fro. Nothing I did would stop the gyrations Turned the knob on the side off to no avail. Started the car and tried to back it out of the barn and the solenoid wouldn't retract. Noticed that the overhead courtesy lights are not working either. What the hey? It is like it's possessed! Any suggestions besides a bible and holy water?
Received 13,511 Likes
Received 2,434 Likes
I have heard that the fasteners for the visors can PINCH and SHORT wiring on dis and reassembly cause all SORTS of strange havoc... weirdly mixed into many systems to do with lighting timers, locking and things hooked into the over all lighting and timer systems around the (maybe) alarm....? I would (quickly) remove the visors and check for wire damage around the bolt ins and the wiring for the visors themselves...... that's just me...
Pull the plugs to the vanity lights in the centre overhead console. Fuse #7 in the drivers' side fusebox is meant to protect things in this event - but it doesn't always catch things in time.
Take a look at this thread of K.Westra's and see if the symptoms are similar:
https://www.jaguarforums.com/forum/x...0/#post1884669
There are some further links in the thread that may help you diagnose. Fingers crossed it's not the BPM
Received 4,341 Likes
Don B (01-06-2020)
