Are My Wires Crossed???
Hello Fellow XK8ers,
I recently had to remove the throttle body on my 1997 XK8 to address a leak in the coolant hose underneath. In doing so, as i tried to remove the electrical connector to the TPS, the connector basically disintegrated under my grip. After replacing the connector, the car ran extremely poorly. Every light on the dash was on. My guess is that I got one or more of the wires mixed up upon reassembly of the connector.
Could someone please confirm the order of the wires from top to bottom being:
1. Blue with white dot
2. Solid Blue
3. Green
4. Black
Many thanks in advance!!!
2. Solid Blue
3. Green
4. Black
2. Solid Blue
3. Green
4. Black
2. Solid Blue
3. Green
4. Black
Book says pin 1=black, 2=green, 3=blue, and 4= blue/white.
michaelh (02-20-2023)
Received 2,432 Likes
From my car, I can confirm, from top to bottom:
Blue (I can't see the white tracer)
Blue
Green
Black/Green tracer
corresponding to pins 4 through 1 on the EG
The 97 EG shows the same as the 98 other than the disclaimer for very early cars (<003300 VIN)
So it looks as if you're good.
Blue
Green
Black/Green tracer
Johnken (02-21-2023)
If l read the diagram correctly probing at the plug should give readings of black-ground, green-half volts idle, blue-half volts idle, blue/white-5 volts
if you get anything like that you could assume connections at that plug are all good.
l would start at that plug even though pins seem correct, maybe something else there is compromised.
car5car
08-12-2019 06:33 PM
