Mystery in need of solving
#41
I was looking at my OBD Data on Fuel Trims and as I have said before, with installing the new purge valve the LTFT have gone up.
However, these high levels only show at idle, so hereīs the 100 Dollars Question: What would tell the ECU in IDLE to pump more fuel to the system than under load?
Curious and Curiouser
#42
If you have basic air leaks, they are usually best seen at idle because there is high vacuum and the leaks are likely a high percentage of the low air flow going in. At high rpm, the high air flow may mask the air leaks.
Have you tried a smoke test through the exhaust? This would detect exhaust gasket leaks, as well as leaks in the EGR tube (pretty common) if you have one.
Jagples
06-18-2019 07:05 PM
Jagples
05-16-2012 02:34 AM
jmalagon42
01-25-2011 07:21 PM
