Namless Cats Dyno Results
Old 05-14-2013, 08:49 AM
oldmots's Avatar
The cats are the most restrictive part of the system. On blown engines, there is much more sensitivity to exhaust restriction, so I don't doubt the gains at all. Just look at the hideous right angle of those factory cats! Good call!
Old 05-14-2013, 01:30 PM
enderle's Avatar
Default 99 to 2004
Originally Posted by avos
Here is another thread with a larger exhaust, where just downpipes (without cats where installed). That yielded about 10-12 rwhp.
https://www.jaguarforums.com/forum/x...es-dyno-41275/
Most other dynos I've seen on our cars with sport cats where about the same. also on my car the sport cats would only have yielded 10 to 15 rwhp or so.
I would also guess that there where other things at play that gave you such a big difference, like jgaxkr suggested or something else, who knows.
Edit: LoL, I missed SteveM post earlier, sorry for the double post.
No the least of which is that that was a much older XKR, mine is a 2004, different engine, transmission, intake, blower etc. They made a lot of changes in the 2004 model year. But I really haven't done that much to the car with regard to the engine. Granted this is a year later. In any case when I put on the new intake and exhaust I'll run it again for a new base line. I know the differences are significant because I was sent a series of powder coated parts from a late 4.0 engine and nothing fit.
Old 05-14-2013, 01:38 PM
Krajcok's Avatar
Originally Posted by oldmots
The cats are the most restrictive part of the system. On blown engines, there is much more sensitivity to exhaust restriction.
Half true.
In turbocharged - yes, turbocharger is a part of exhaust, free flowing exhaust is the best way to improve turbocharger spool.
In supercharged - no, the exhaust is as important as in N/A engines. You do need a backpressure to get good torque and hp curves, especially i low and midrange engine speed.
Old 05-14-2013, 11:58 PM
avos's Avatar
Received 1,067 Likes on 761 Posts
@Enderle,
The differences you mention aren’t that big on the engine, and my experience actually was also with the same engine as you have where I would guess at max about 10 to 15 rwhp. For another 4.2 Car like yours (from 2005), it was about similar, even though he had also a larger exhaust on top of the sport cats. Am also not convinced that the stock cats are so bad, 1st of all the area is bigger (/diameter) than the sport cats, meaning you just can’t judge the flow purely based on the amount of cells alone. The lower bend is almost as a funnel, as the pipe is over the full lower length of the cats.
A 30rwhp is something noticeable, so that I certainly believe, but the question is why so many others only report max half of that gain, and you more. So chances are that there maybe was something else at play why your 1st run was lower.
Anyway, please keep the info coming, the more people share dyno results, there more we all learn. Even though if not all results will be as/or above expected.
Old 05-15-2013, 04:28 AM
Premier1one's Avatar
Thank you sir...much appreciated.
Old 05-15-2013, 10:24 AM
steveinfrance's Avatar
Originally Posted by Premier1one
Every village needs their idiot
Let's keep things civil, please.
Old 03-16-2016, 12:30 AM
ET1's Avatar
ET1
ET1 is offline
Just did the 200 cell Nameless cats on my 03 XKR at 127,000. Coming up on smog and barely passed last time, so I knew one of my cats was shot and I wouldn't pass so I pre empted.
I previously did the over axle delete and removed the mid boxes as well which I think enhanced the benefit from the NP cats.
I agree with Enderle's 30 HP numbers: there's an appreciable increase in response. Not huge, but definitely noticeable.
On a final note, the car snarls and crackles and pops like the F-Type now.
Money well spent..
aode06
07-28-2023 02:26 PM
hkmcmast
11-29-2015 06:56 AM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
caldoofy
09-28-2015 08:43 PM
Quick Reply: Namless Cats Dyno Results
