Need 01 xk8 non-nav stereo wiring diagram
Thanks, but the wiring diagram does not match my car. I put a chart at the bottom. Thanks for the link WhiteXKR
PDF lists
y+ / YR - LH front spkrs
w+ / BG - LH rear spkrs
B + / BY - RH Front
WB+ / YB- RH Rear
GB Antenna
RW Radio control switch - sttering wheel
RB Dimmer
My car has this
B
BY
GW
GB
RB
RG
RW
OY
Y
WBl
BG
Chart
W - White
B - Blue
Bl - Black
G - Green
Y - Yellow
R - Red
O - Orange
PDF lists
B + / BY - RH Front
WB+ / YB- RH Rear
GB Antenna
RB Dimmer
My car has this
B
BY
GW
GB
RB
RG
RW
OY
Y
WBl
BG
Chart
W - White
B - Blue
Bl - Black
G - Green
Y - Yellow
R - Red
O - Orange
Jaguar is notorious for changing wire colors without documenting them, especially with the audio system. Use the conector pin numbers on the diagram instead of the colors...that should be more reliable. Normally at least the corner pin numbers are embossed on the connectors, and you can count out the rest from those reference points. You may need a bright light and a magnifier to see them, however.
randyb (09-15-2012)
The diagram shows the speakers going to IC19, which according to the diagram is the white connector and all it has is the 2 brown/red wires, white and black.
IC20 is supposed to be the yellow connector, but all it shows going there is the dimmer wires, VSS, antenna and steering wheel controls.
So has anybody successfully recorded the pinouts on the yellow connector (IC20)?
There are also connections for the phone on IC20. What other connections are you looking to match up to your aftermarket stereo?
Guy-Pierre Boucher
09-16-2015 05:55 PM
Daniel Howden
09-13-2015 02:28 PM
