Need advice I think it looks good ..
Glandaniel, as I recallTRAC OFF includes adjustment of engine timing and fuel (this is same as DSC) to reduce power to rear wheels when loss of traction is recognized, plus brake application on individual wheel(s) to reduce wheel spin increase traction.
In summary trac off adds braking. Reminds me of last time I drove her in a couple inches of snow. Started up nicely, but press trac off = wheel just spins.
Gosh it's late, I haven't read the specs on the difference in a while now. I welcome corrections and additions.
John
John
The following 2 users liked this post by Johnken:
giandanielxk8 (07-06-2019),
Kriss Vector (07-05-2019)
Kris, a few notes to consider.
The light colored dashboard on these early models gets a bit annoying in the sun - reflects on windshield ( have this same color so I know).
She doesn't appear to have premium stereo.
Heated seats? Hard to tell from photos.
While looking at photos see if you can make out the button nearest drivers side, same row as heated seats. Does it say DSC or TRAC OFF? I believe Trac Off is the preferred option.
These are small issues to some, important to others. It's up to you.
Leather looks great BTW. Interesting dash wood veneer choice. Some might prefer burled walnut. This might be a different wood. Elm?
Hope it helps. John
Hope it helps. John
Are all Jaguar owners retarded? I didnt ask for personal opinions, I asked for mechanical, technical advice on this particular vehicle. If i wanted personal advice, i would have gone to Facebook, I tought you guys were professional.
That's a harsh comment considering you're the one looking for advice. IMHO the 1999 LS conversion you're looking at, has been heavily modified and is not to the taste of many forum members. However the main feedback is that it's overpriced and so resale value is an issue. However if you're looking for a X100 keeper, with a LS engine, I would check other bits of the car as below.
1. The X100 has a sports mode and cruise control function. Does that still work in the LS swap?
2. The original cabin climate control has a blower with coolant feeders from the engine. Does all this still work 100%?
3. Was the car's suspension lowered to match the modified bodywork? Upper strut mounts are known to fail, leading to low ride height and knocking.
4. Car would have come originally with a ZF5HP24 gear box so what are the changes to the transmission - TCM, driveline, diffs etc. Is the J Gate gear stick module still 100% operational.
5. Has ABS been modified?
6. Car came with a CAN bus control network, where different modules talk to each other. This must have been updated. What does an OBD DTC check reveal? Otherwise future maintenance might be an issue trying to troubleshoot problems.
7. The convertible top is hydraulically operated, and you should check that all the pipework is relatively new. Easy to spot old original pipes as their rubber sheathing will literally be falling off now. 1600psi pump is located in the rear RHS of the trunk, so easy to access. The car is infamous for the "green shower" as the hood latch is hydraulically operated too and connections here are known to fail - hence the "green shower".
8. Doors are known to sag at the hinges and windows' regulators and microswitches tend to fail due to the age of the car. Are the seals 100% otherwise top will leak and you'll have excessive wind noise.
9. Do the rear tail lights work? Any flickering? There's a known ground fault, where forum members have to add an additional ground to the rear tail lights main body (using just a pop rivet!)
As I've always said, if it's your car, do what you want. That's certainly what the PO has done in heavily modifying the 1999 XK8. It won't be to everyone's taste, but the main man for LS swaps seems to be Andrew from Jaguar Specialties, and I would certainly ask his opinion on the car you're looking at.
Kriss,
You’re welcome. Check for rust too
Generally it seems that USA X100 cars’ body work are in better shape than the UK cars in terms of rust. Weather and salted roads....blah....blah....
Not sure of the ownership history of your car, but worth checking for signs of the dreaded tin worm especially in humid USA areas like Florida.
Kriss Vector (07-06-2019)
#28
Guys-
This is Andrew from Jaguar Specialties. I have seen this car before and it "may" have been done using our kit. And if so, just to clarify any misconceptions, our LS XK8 Conversion kit includes a special proprietary CANBUS interface that allows the new LS engine to talk to the car. With that piece in place, the car operates as before and all functions work (gauges, AC system, speed sensitive steering, etc.,.). I am only posting this for information and not to stimulate any discussion on the merits or value of this conversion or the XK8-LS conversion in general. There is a lot of misinformation out there on these conversions, and I wanted at least this key point to be crystal clear.
To the gentleman considering this car, please have it professionally checked out BEFORE you buy. Put it up on a rack. To confirm this is one of our kits/conversions, snap a few pics of the engine area from underneath and send them to me-I will be able to tell. Only our kit has the special CANBUS interface which is critical, and no one else offers anything like it,. Without it, (if this is not our kit) the conversion/car is not worth your time. Nothing will work without it and there is virtually no way for an individual to correct that....
I hope that helps
Andrew
Jaguar Specialties
I hope that helps
Andrew
Jaguar Specialties
The following 2 users liked this post by JaguarSpecialties:
DavidYau (07-10-2019),
Kriss Vector (07-10-2019)
#30
Guys-
I hope that helps
Andrew
Jaguar Specialties
I hope that helps
Andrew
Jaguar Specialties
BugDoc
110
04-28-2013 01:10 PM
chinny4290
10-22-2011 09:41 PM
