Need Advice Purchasing XK8
Guest
Posts: n/a
I am interested in purchasing an XK8 coupe or convertable, in the range of 1999 to 2003. What are common problems/maintenance issues, and are there any model years to avoid?
Is there a source to purchase a shop manual? Any advice on where to find one in Central Ohio?
Thanks,
Thanks,
Don't by anything older than 2000. I bought mine in Canton Ohio, but I live in Chicago. I would just find a nice one on ebay.
If you can test drive a few of them, and try to get a feel for them. A big problem with our car, and alot is the wheels. You want to make sure the wheels aren't making any wierd noises so ride with the windows down, and you want the car to be driving strraight on it's own...cuz the wheels ill cost thousands in repair if they have trouble.
Have the coolant and gaskets checked...and look for loose wires, those can be annoying to deal with.
If you buy something older than a 2000, the engine will fail eventually due to the nikisil problem. Also, a good price for a 2000 model is between 15-17 grand. We paid 14,800 for are 2000 convertible with 70,000 miles. You don't want to pay to much, cuz I could see people getting ripped off on these cars. They are great cars, just a lot of depretiation...so you should get a huge bargain.
I've not had problems with my 97.
I was talking to a Jaguar mechanic while doing an engineering job on an S-typeR at a dealer.
He says the only real problem the early ones have is that they were shipped with a badly designed thermostat. This causes the engine to overheat, and burn out the oil that's trapped in the Nikisil liners, causing a drop in compression.
It also will overheat the timing chain tensionsers causing them to break.
In the case of the Nikisil, you put oil down the cylinders, and turn the car over a few times. You then start the car and wait for the smoke to clear. Your compression whould have returned by now.
I hear the only REAL problem with the Nikisil is when you live in an area with high-sulfur gasoline, which eats away at the liners themselves.
If you buy a pre-97 it should be fine as long as it has run non-cheap gasoline, and you have the thermostat and timing chain tensioners updated.
I've had all this done on mine, and it's a great car.
The original time chain upper tensioners had lots of problems. They would break and scatter the engine. Also, the orginal plastic impellor water pumps had extremely high failure rates. The impellors eroded away and eventually moved no water; hence, causing overheating.
ORIGINAL: Yurikaze
I meant pre-2000.
High sulfar gasoline is mostly only a problem in the gulf states.
I know that most California cars will be a safer bet due to the requirement for lower sulfar gas that was instituted before the XK came out.
But DON'T BUY pre-2000.
If no one buys them, this will drop the values of the pre-2000's and all of us that actually like them can buy more.
ORIGINAL: 93xj6
Second it's stupid to buy anything older than 2000 because there's no way to no if it's been driven with high sulfur gasoline, and there's no way to really know about your own region. It just makes sense to buy a 2000 or newer
And, the warranty is transferable. It's not available to Owners. Only through qualified Dealers.
Jack, no one's calling you stupid.[:@] Just post more pics to the hot babe section. Caddi's out doing you!
Yurikaze, blow off the Nikisil worries. I think people just like to say it because no one else knows what they are talking about. The timing chain tensioners are the big killers in these cars. Correct those and you have a screaming fine car!
ORIGINAL: Jack Rabbit
You calling me stupid Bro? I have an unlimited mileage drivetrain warranty with mine through AutoSource that I purchased from the Ferrari Dealership who sold me the car. I think I'm covered for internal engine problems!
My dad has a 4 year warranty for his drivetrain too, but if the engine needs to be replaced even with a warranty that is hectic. You gotta co-pay some of the stuff, and it's hard to get warranty companies to spring for stuff occasionally.
And you probably didn't know about the Nikisil problem or you woulda bought a newer xk8 I bet.
Guest
Posts: n/a
ORIGINAL: 93xj6
![EEK!](https://www.jaguarforums.com/forum/images/smilies/eek.gif)
1997 -2000 MY XK8's are great values if you do your due dilligence.First of all, the Nikasil problem only occured with high sulphur content fuels and in the U.S. this was not a major issue due to low sulphur content in most areas and now none. The incidence of engine failure attributed directly to Nikasil is minimal compared to damage caused by faulty tensioners or just neglected maintenance. A simple compression or blow by test will rule this out.
My 97 with 29,000 miles was purchased and immediately went to an independentJag service provider for replacement of following items Secondary Tensioners, Thermostat, WaterPump,Top Hydraulic Fluid and a cleaning of Throttle Body and MAFS. It has provided me with a trouble free driving experience that is hard to match.
I don't see how they are great value tho, I paid less for my 2000 then jack paid for his 97. They cost about the same, even tho a 97-99 has known engine problems not to mention slightly less horsepower I believe and just that they are older.
Any car you purchase, it tends to make sense not to bey the first few production years because the kinks are still being worked out.
Charlene n John
09-28-2015 06:01 AM
OkieTim
09-08-2015 04:48 PM
deanh
09-06-2015 08:20 PM
