Need basic help '99 XK8 possible fuel leak
this is quite common, as a matter of fact, mine had the same leak.
Often, it is a partially open/closed cannister close valve. On my car, the fuel vent line rusted, dropping pieces into the CCV, causing it to stay open and give the code for the leak.
Others have just replaced the cannister and left the vent tube, I had both changed so as to prevent it from happening again sooner.
if you search the xk8 area, you'll see a few threads recently about it, with locations and how its changed. gluck!
OkieTim
09-08-2015 04:48 PM
