need help disconnecting ac module and radio
It's a few years since I last removed the centre console and the radio but I can't recall any particular difficulty with any of the connectors. The blue one looks as if you push in the outermost tabs and the block and wires on the left will pull out.
The yellow one might be sort that has a hinged latching mechanism which pulls in the block and secures it or the black part maybe needs squeezing in at both sides so it unlatches from the metal plate and the yellow block can be pulled out. Close examination should provide the answer.
Richard
Richard
