need help with trans shifter plate
Yes, it will interchange with any xk8 bezel that has only the sport switch (I think 2003 and up).
To get it off, place a credit card in between the j-gate and bezel, from the top, down into the assembly...there are four (4) tabs that will release when you slide the card down in between them, at 1:00, 5:00, 7:00 and 11:00. Go slow, it'll come up with each tab location release...wiggle free.
sls-101 (08-12-2018)
Cellslinger... be very patient and careful when getting at the retaining clips or tines on the bezel to remove it. I removed mine and managed to break one of them. I used a Subway frequent buyer card and just about mangled it beyond recognition - maybe a Visa card is stiffer. It was hard to keep the ones that released to stay released when you worked on the others. Anyway, take your time. I eventually got it done and reinstalled (had to reinstall my S mode switch, which I had pushed into the console.
- Bart
- Bart
Flydutch thanks for the insight i'm going to order one I found on ebay next week and i'll let everyone know how it goes ill try to be careful as its not a necessity just bugs me to look at.
Another question for all of you with great wisdom. I've been looking at extended waranties anyone suggest a good company or ones to stay away from only expect to put about 5k per year on my car and the quotes have been from 2500 to 5500 for 3- five yrs, my head is spinning!!!!!
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Thanks for the help flydutch and h2o boy, the credit card worked great. If anyone is interested I ordered a 1997 j gate or shifter plate and it is not compatible with 2003 one of the plugs are different female instaed of male and the markings on the plate are different 234 instead of 2345 on the manual side. found a 2005 and it is identical. Thanks again for the input.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
