Need info on missing trunk panel mount
the forward trunk panel of my 2004 XK8 is loose and warped -appears to be missing
a mounting strip or clips or? there are 2 slots in the sheet metal panel behind the carpeted panel
that look like they may be mounting points ?
Prethanks for any advice or help
Received 2,400 Likes
The car in the video above is a coupe. As you have found, there is an extra panel on the convertible. Please add the extra detail to your sig.*
On the coupe, the rear trim is 'held' by the trunk side trims and some strips of velcro attached to the fuel tank restraining straps. Looking at picture #3 in the tutorial on member Gus' site:
JagRepair.com - Jaguar Repair Information Resource
there seem to be a couple of similar strips attached to the metal panel you have in front of the tank itself.
It's a bit of a half-hearted effort, TBH. The velcro isn't really up to the job, and neither is the glue used to attach it![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
*edit: Signature is accessed via 'User CP' on top LHS of page, scroll down to 'Edit Signature'
thanks for all that info..as a new owner I had no clue.
I am afraid since the panel is warped velcro may not hold it in place
I was considering using some nice chrome sheetmetal screws with a counter sink bezel washer
I also have some OEM /GM black trim screws that would not show as much
There are 2 oval shaped slots in the metal panel on each end that look like
mounting points for the carpeted panel?
