Need Pinout for 2001 base radio connector
IC19-3 is yellow
IC19-8 is yellow/red stripe
IC19-10 is blue/yellow stripe
IC19-9 is blue
pins are numbered on the connector, you may need a magnifying glass
does it look like this
174481-1 Product Details - TE
or this
174933-1 Product Details - TE
IC19-9 is blue
or this
These are Standard and Premium Audio Diagrams:
Note: You can use the Zoom capability of your .pdf Reader for a clear View.
Do you happen to have that wiring diagram?
That yellow 26 pin connector is IC20..and there are no pins on that connector that go to speakers AFAIK.
You will have to tap into IC 15 an 18 pin white multilock 070 at the amplifier in the right side trunk.
There is a harness from radio to amp but I don't know pinouts or audio level outputs on those in -115 pdf above.
randyb (01-15-2013)
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
