Need rec on window/door rubber treatments
Old 06-11-2017 | 08:00 PM
Charbinjr's Avatar
Default Need rec on window/door rubber treatments
Hi. Just started replacing some door and window seals. Does anyone recommend a particular product to extend and rejuvenate these rubber parts.
Old 06-12-2017 | 02:59 AM
I've moved your question from General Tech Help to XK8/XKR forum. Window seals are a known issue on your model.
Old 06-12-2017 | 05:03 AM
DevonDavid's Avatar
Not sure if you can get it in the US, but I use this and it's good :
Amazon Amazon
Orthodixie (06-12-2017)
Old 06-12-2017 | 07:46 AM
Jon89's Avatar
I have a tube of SilGlide that probably dates back to the mid-1990s. I use it very sparingly and it still holds up after 20 years or so....
Old 06-12-2017 | 09:25 AM
Charbinjr's Avatar
Thanks all. Gummi Pflege Rubber Care Stick 100ml Had great reviews on eBay so placed the order. It is from a US based vendor.
Old 06-12-2017 | 08:51 PM
Charbinjr's Avatar
BTW fellow members, don't overlook what seems to be a trivial issue. Each of the top rubber seals above the driver and passenger windows cost $132.00 and there are 2 pairs more associated which cost a LOT more. Just a heads up.
Old 08-13-2017 | 05:43 PM
JCam's Avatar
Default 2002 XK8 door rubber
Can anyone tell me where to order the rubber seal that is over the driver's side window. The one on my wife's car has split in several places.
Thank you in advance.
Jamie
Old 08-13-2017 | 06:51 PM
Try forum Sponsor S N G Barratt:
SNG Barratt - The Ultimate Jaguar Parts Specialist
Mentioning forum membership gets a 10% discount on most parts.
Old 08-13-2017 | 08:43 PM
Jandreu's Avatar
Plus 1 on Silglide, I've used it for years, cheap and works.
