Need to replace cracked shift indicator
Looking to replace a cracked shift indicator plastic piece. It indicates what gear you are in....black with white lettering. I just purchased a 2002 xkr and need a few cosmetic repairs to make it look outstanding....really excited...this forum is awesome....packed with knowledge. I could also use references to find new and used parts without getting whacked at the dealer. Thank You Gentlemen and Ladies probably.
From Jaguar, that part is not an individual component and the set is like $550. Used 5 speed gates are available much cheaper and occasionally you can even find just that part on eBay.
That said, there is an aluminum one found on eBay for around $65.
https://www.ebay.com/itm/302281676758
Check forum sponsors for parts sources. They are all good.
