Needing VIN decoder help
I am trying to decode VIN SAJJGKED3AR014145 in order to see, what kind of Trany is in this car.
Also to ascertain if an Auo trany from a 1999 XK8 will fit into this car.
Tried many / all VIN decoders online with no satisfactory outcome.
Any and all diligent responses are thankfully welcome.
Thanx in advance for same.
crbass (06-23-2020)
I have installed all sorts of combinations of AJ26 and AJ27 ZF 5HP24 gearboxes into X308 sedans and a few X100 4.0 liter.
THEY ALL WORK!
I always replace the forward (A DRUM) drum with an updated unit before installing in the car as well as a fluid/filter change.
Just recently I installed a 1998 X308 (AJ26) 5HP24 into my wife's 2001 (AJ27) X308 sedan.
New forward drum, fluid and filter and it drives normally.
You can use any XK8 or XJ8 5HP24 as long as it was used in AJ26 or AJ27 car.
THEY ALL WORK!
