is planning a set of brake discs for our Jaguar XK8 / XKR (with Brembo brakes) with brake discs 2 pieces separable in 2 versions: standard diameter and increased diameter (with shim plates for pliers).
There is also the possibility to customize the color of the central part, the type of cooling drilling (drilled, slotted or both ) than also the diameter.
