--- NEW! 83mm TB for our XKR 4.2 is going to be ready! ---
#181
I have only done this on the 4.3 STR/XJR as there is an easy fit. The XKR is a different beast, but also there the stock intake is a restriction.
#182
Avos, I reached out to PRO M for the 92 MAF. They have it and said they can set it up with the Jaguar AJ34 4.2S parameters but said that I would have to tune the car once I install it. Is this true? Do they not calibrate it to work with our stock injectors and the adjusted flow rates?
I had my ECU sent to UK to get tuned by Paramount like 2 years ago. It was a long and expensive process and not the best hp/$$$$. I would hesitate to send it back to them to tune it again to compensate for the larger MAF, especially since we cant run the car on the dyno and get live data to make adjustments off of.
Do you have any insight you could offer?
You may want to ask them why they think you need a ECU tune.
jazzyjags (07-24-2020)
#183
I wonder..If you really want to see more parts like this, for upgrades or obsolete parts, .who of you is able, and willing to join to help finding metal casting services using lost wax - the one used for this size and quality- collapsed due to COV19 .This model up to wax is fine...but suppliers for casting ..not the casting itself, but their culture --and their work ethics.. ah. that was hard even before lock-down
cristian.s (07-24-2020)
#184
We will know for sure though, I am doing my "before" or baseline dyno next Wednesday. I will make an unboxing video for the TB when it arrives and post it on my YouTube Channel. Then I plan to install the Luca TB along with the ported plenum and polished outlet. I will then do an "after" dyno to see how much improvement there is and can share impressions with the group if interested.
#187
#188
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20200806_155156_761327fc9d329e76fc65ac2fd48bb5d5705697a5.jpg)
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
#189
#190
#192
Btw those coolant lines aren't necessary , could of removed those from the mold to make things easier .
#193
Recommending removal of the coolant lines isn't quite correct. In southern regions in the USA where it seldom gets below 32 degrees, the coolant lines can be bypassed. But in northern regions where temperatures get down to 0 degrees and lower, coolant flow is important to keep ice from forming in the throttle area.
#194
#195
#196
#197
Robinus, I did. “I am really sorry, but the old lathe I used to bore those huge TBs quit working a few years ago.
I could not get it repaired.
I replaced it with a modern lathe, but it can't spin castings that big.
I am not able to help you with that TB.
Thank you
George
www.maxbore.com”
Alex, I can’t wait to hear if wherever you sent yours to was done.
Thank you
George
www.maxbore.com”
User 42324 (12-04-2020)
#198
George
www.maxbore.com”
George
www.maxbore.com”
#199
If you are looking for a machinist to bore out a throttle body, don't get hung up on having it bored using a lathe. Any qualified machinist that can set up a numerically controlled mill or CNC mill should be able to very accurately bore out a throttle body. Using a CNC setup one could flare the upper OD to a larger diameter and/or other features. If the CNC has rotary table capability that could make the job even easier.
If the shop has a centerfinder fixture, they could quickly find the exact center of the existing bore, then swap over to a mill bit to mill it to a close-to-finished diameter. Then they could put in a surface finishing grinder/cutter/polisher and get the finish to whatever you want. (Even a super fine polish.)
Should be a piece of cake.
I bore out larger holes on a fairly regular basis using my mill and rotary table. My mill is a manual one and is tired and it would take too long for me to achieve the exact diameter and finish one would want on a throttle body bore, but the concept and approach is the same.
The following 2 users liked this post by Tijoe:
avos (09-01-2020),
#200
Would agree as well, which would leave the throttle blade as (last) major hurdle.
I would guess that maxbore could be able to help there, and the small mods to the shaft would be easy to do as well.
One can always try with a cheap 2nd hand unit from Ebay to check what the maximum diameter can be, before you do the right one.
At least that would have been my approach if I needed one.
