A new Avos project just about to be finished
Hi Guys.
Jeff from Tuscon asked if I could share our project with XKR'es on the forum as I am about six months ahead of what Jeff is about to do.
So here I am.
Its good to be finally on the forum after many years of lurking. Big thanks to all the posters and moderators for your inputs and enthusiasm. I have a Silver 2001 XKR which has been heavily modified using all the information, posts and advice presented here on the forum.
Briefly,
My car ripped off the supercharger pulley on the French autoroute, terminally damaging the end of the crank. The cost for repairing the damage wasn't financially viable. Out of desperation for any options I contacted someone called Avos, from this forum, directly to his personal e-mail for any advice.
A long story but,
Andre very kindly offered to take my broken car as his own project, I'm still blown away at this incredible generosity, he has a real job and a family to look after.
Given this unique opportunity we have put together something really quite special and this five month project will be coming to an end in a couple of weeks.
Let me share what we have been up to.
For starters, we have a new Range Rover sport RR 4.2 ltr engine. with reprofiled cams, Kenne Bell booster pump for better fuel flow with updated pressure regulator. On top we have the Avos (Kenne Bell) 2.6L high pressure TS supercharger. 90 mm throttle body, cool air intake system with K+N filter with a 3.5" MAF sensor and Miltech exhaust on the hot end.
To help keep the intake air cool we have an Avos's custom intercooler radiator, a Bosh high flow coolant pump. We have a new cross beam bumper bar that increases airflow to the radiators with a new grill fascia.
Further back we have had the gear box serviced and the new blue top solenoids fitted for firmer shifts. this is linked to an OS Giken TCD limited slip diff with the crown and pinion gears all shot peened to harden them up.
Because of the extra power we upgraded the brakes with Brembo calipers, Goodridge hoses, centric discs, Pagid pads, with adapters plates for the larger Jaguar 20" vortex wheels. The wheels have been balanced and the car has been realigned after the polypropylene bushing of all the bearings. OH, and also fitted with the lower firmer springs.
I have tried to keep the car looking externally just the same. I cant bring myself to change that original look. It is just so dam Pretty.
In two weeks time I fly up to meet Avos, for the first time, have a beer or two, then after that drive the 1000klms back to down to Spain.
In six months time Jeff from Tuscon should be doing pretty much the same, but in the meantime, I will keep you guys updated, as well on whats happening. I am hoping to get a few good video's and lots of pictures of our results.
Very best wishes to all, catch you soon,
Colin.
So here I am.
Briefly,
A long story but,
Colin.
User 070620 (03-11-2014)
Received 6,307 Likes
Wahoooooooo!
I'm so glad to see Capt'n Col on the forum! This fine fellow has been a blast to speak with about the development of his fine car. AVos has certainly been busy on this one.
I look forward to seeing and hearing about his driving adventure that is coming up. What a lot of fun that will be!
Cheers Guys!
This week Avos is running the engine in (because it IS brand new).
Then at the weekend doing the first oil change and full system check before the first full power tests.
We have had some interesting delays, one is the fitting of the new larger wheel setup in the original wheel arches with the lowered suspension.
and the other is the cam timing with the more aggressive cam profiles. Both fascinating subjects and both sorted.
The car has been out of commission for nearly 7 months now so you can only guess at my general levels of excitement. It is a little tempered tho with the thought of driving back to the warmth of southern Spain through the normal north European winter conditions in a car with the HP levels that has yet to be confirmed.
But again very excited.
Catch you soon, best wishes,
Colin.
Colin.
Just a quick update
Hi guys,
Four more days to go before my wife and myself fly up to Belgium to collect the project and most importantly meet the man.
A few interesting updates. Andre unfortunately collected a flat tyre whilst running the car in but has now put his wheels on to complete the run in process. The new booster pump has been fitted and the car is ready for full power tests.
One small problem. Snow. (Great Photo Andre)
Before the snow arrived Andre seemed to be happy with the power delivery. I feel this must be a little bit understated with the possible type of power delivery available. (Good man!)
So our drive back to Spain, 1050 kilometers, could be quite an interesting story.
Catch you soon,
Colin
Catch you soon,
Colin
Received 2,190 Likes
Great quote!
Hi Guys.
I caught this great quote today and thought I should share.
As I see only colder weather with snow coming I took the opportunity just now during my brake to take a test drive. Everything is as expected (boost/airflow/ignition), so for me good to go! It was tricky as I needed to do 3rd gear runs on public streets, so speeds of 180km/h, as 2nd gear would only cause spinning wheels.
I hope it's no one we know and I hope he didn't get caught.
It does sound more like a motorcycles performance than a cars.
Colin.
Colin.
Received 9,007 Likes
