New Block required
Old 01-17-2015, 05:14 AM
red5's Avatar
Default New Block required
Hi all
Advice pls from the masses.
My new to me 99 xkr requires a new block - the current one is shedding its lining.
My options
1, I get a replacement XK8 engine from a breaker and put my super charger bits back onto it , coming in currently at around £450 - no long term guarantee that the engine wont have the same problems but easy one out one in .
2, I get the current block relined to steel with 'racing green' coming in at £1200 , more expensive but a better long term option , having to rebuild the engine will prove a test to me in my limited experience.
3, A new engine from Sng is coming in at a few of £K ,and more than the car is worth - not really on the table , but put down so you don't put it down as another option.
4, I get rid of the car and wlk away 4k worse off
Old 01-17-2015, 05:34 AM
ccfulton's Avatar
Received 1,108 Likes on 764 Posts
1) You can't use a short block from an XK8 for an R, if that is what you are meaning, the pistons and compression ratio are different.
1a) if you can find an R from a breaker, that might be an option, although the cost of a supercharged engine may approach #2
2) Seems like not a bad choice, if the rest of the internals are in good shape. Is probably what I would do.
4) It's hard not to love these cars, even when they are sick. Personal choice and depends on your priorities, but I wouldn't give mine up for anything.
red5 (01-17-2015)
Old 01-17-2015, 05:58 AM
GGG is offline
Received 16,867 Likes on 12,186 Posts
1. the economic answer in the UK is put in an engine from a breaker where there's good availability at a reasonable cost.
2. the 'right' way to do it is reline the block to maintain originality.
I'd have a hard time convincing myself to go with option (2) given the current values of XK8/XKR. Depends on the overall condition of the vehicle.
One piece of good news is Classic & Sportscar magazine feature the XK8 in the February 2015 edition as a good buy and future classic.
red5 (01-17-2015)
Old 01-17-2015, 06:22 AM
Marc's Avatar
Ouch, that is a dilemma. Option #2 seems to be the best. Prepare to dedicate yourself to seeing it through. Take lots of pictures from lots of angles as you go thru the tear down. You going to need some shelves to store your pieces safely while progressing. Plan ahead often, because life does go on, and it is too easy to get side tracked and derailed. Not trying to discourage, but, If you're not too experienced, or tooled up, or don't have proper workspace for that matter, finishing complicated things in a timely manner will be a test not just for you, but for family and friends too. Sell the car and walk away from it, because I got a feeling there's more wrong with any 16 year old car than just the liners.
The following 2 users liked this post by Marc:
red5 (01-17-2015), scoobie (01-18-2015)
Old 01-17-2015, 12:34 PM
red5's Avatar
Thanks for the responses so far guys - invaluable
I was unaware of the difference in the compression rates in the engines , so have asked for a requote on xkr engines from the breakers - hopefully this will reset the snag.
Old 01-20-2015, 07:57 AM
P700Dee's Avatar
Replacement XKR engines are easily sourced in the UK. Contact Design XKR Leading Independent Jaguar specialist The Big Cat Workshop based in Andover they can source you an engine (probably http://jagspares.net/ £950 on e-bay 07950377255 would collect and fit engine to car ) and they can probably better the Racing Green quote if you want to "reline" your engine. Why do you think it needs re lining ? How have you damaged it ?
If you wanted an upgrade you can use the 4.2 block with the 4.0 ancillaries. Want a third quote try www.tomlenthall.co.uk
red5 (01-21-2015)
Old 01-20-2015, 08:08 AM
RaceDiagnostics's Avatar
+1 for an engine from a breakers, swapping an engine is going to be a walk in the park compared to rebuilding.
I did a V8 engine swap as pretty much my first auto diy job a few years back and it worked out just fine.
red5 (01-21-2015)
Old 01-20-2015, 11:26 AM
brgjag's Avatar
If you have access to the GM cars with the LSx motors, do the conversion, it is pretty much a direct bolt in, no fab work. MORE power and reliability.
http://www.jaguarspecialties.com/xk8-lsx.asp
red5 (01-21-2015)
Old 01-21-2015, 02:54 PM
red5's Avatar
Thanks all
Update
Have spoken to Trevor at Jag spares in Penge , and he has a steel lined 2001 block good to go - and has priced very well. I am 99% going to go down this route , but am currently trying to find out under the radar if it will change my veh tax rate for the car - big jump post yr2000 to £500 a year , currently only on £230.
only a small thing to consider but over time (Yrs) this will add up.
Any one any thoughts?
Old 01-21-2015, 05:23 PM
Don-T's Avatar
Originally Posted by red5
Thanks all
Update
Well, on this side of the pond, it would still be whatever year the VIN said it was. Parts replacement doesn't effect the year.
red5 (01-22-2015)
Old 01-22-2015, 03:36 AM
P700Dee's Avatar
Whilst you need to inform the dvla of the engine number change it will not change your tax.
red5 (01-22-2015)
Old 01-22-2015, 02:42 PM
red5's Avatar
ok - car will be in Penge with Trevor from next week - hopefully the right foot induced smile will soon be back on my face.
thanks for all the advice gents - will let you know the score and put up a pici or two when I collect
Old 02-13-2015, 02:52 PM
red5's Avatar
Got the good news in the week, car ready for pickup, following some not great stuff last week , second hand engine , as already discussed , new abs sensor , roll bar , bushes also required.
Anyway we don't dwell on the cost ...... But a fantastic drive back from penge to deepest Dorset today trying to keep it below 3k on the revs purely on advice from Trevor
I did manage todo it for the first 2 hours ! , however we touched 5k a number of times and I'm happy to report the smile is back on the face
Norri (02-13-2015)
Old 02-13-2015, 03:19 PM
brgjag's Avatar
how many miles on the new engine?
Old 02-13-2015, 03:32 PM
red5's Avatar
60 k on a 2001 block
Donor was impailed by a fence, not a good look
aode06
07-28-2023 02:26 PM
jagtoes
04-22-2016 07:37 AM
dieseldoc
09-28-2015 01:17 PM
Woznaldo
09-26-2015 11:02 AM
Quick Reply: New Block required
