New to forum
New to forum
I purchased a 97 XK8 convertible with 76000 miles on it. No real history but Auto Check says Electrical system service in 2006 at 36758 miles,Vehicle Service in 2007 at 48776 miles Brake Service & Electrical system service in 2008 at 60309 miles. All done at dealer. I found a receipt for new black leather interior done in 2005 and a yellow sticky note saying the timing chain was replaced in summer of 2010 for $1900.
I am getting the ABC/stability & traction warnings so I'll start with cleaning the sensors for this. I also get the low brake fluid warning (its full).
I am going to call the dealer to see if they can give me more info on the service and get the radio code.
What Sam said. Also, the water pump and thermostat are suspect on your MY and should be updated. Overheating can happen otherwise.
Convertible top: potential for "green shower" here. Until you can research it, don't cycle the top with the car's engine running. Hydraulic pressure is higher that way than if you raise or lower it engine-off.
Good luck.
Good luck.
