NEW full adjustable COILOVER KIT Bilstein-Eibach. Special Discount for Jaguar Forums
hi at all,
the technical center BILSTEIN Italy (NTP - Eibach Bilstein Italia | Home ) has developed for me a Full Adjustable Road & Track suspension kit with 10 settings for the damper. Using ERS Eibach springs and Bilstein dampers B16 PSS10.
I have this kit from few months and I must say that it is extremely quiet, it has a great grip and maintains optimum comfort.
The adjustments on the front shocks are inside the bonnet, very easy.
The adjustment of the rear shock absorbers ( that have the 40mm rod! ) are in the lower part, it is not necessary to lift the car to adjust, just lie down and with two fingers to rotate the ferrule that remains inside the old support for the spring .
Anyone want this kit, please send an email to: sale@ntp.it
the price is 3795 Euro + VAT but I've got a special 15% discount for all my friends and fans XK8 / XKR 1996-2006
If you are interested in even the discount, when you send the order, write MANNI CONFIGURATION and sends the email also to me for information ( Cc.) luca.manni.plc@gmail.com and will automatically discount!
Jaguar | NTP - Eibach Bilstein Italia
( i think that VAT only applies in the EU. Anyone outside EU does not pay VAT but not shure about it )
The following 6 users liked this post by User 070620:
bcprice36 (03-21-2019),
enderle (05-21-2016),
GGG (05-20-2016),
giandanielxk8 (06-27-2018),
sklimii (05-20-2016),
and 1 others liked this post.
User 070620 (05-20-2016)
yes. the same for XK8-XKR from 1996 to 2006 .
but for more info about this kit, contact directly www.ntp.it/english/motorsport/marken/jaguar.html
The following 2 users liked this post by Jandreu:
Panthro (05-29-2016),
Received 4,302 Likes
unprofessional behavior by all of this factory . NTP Biltein Italy are a very professional team, and i had doing any miles before to show you this product.
But i'm really happy now. I have a very racing car ( but you must consider that i have also Powerflex Black Series kit, upgrated front and rear anti sway bars, lsd diff, 15 mm spacers )
you can only change the springs and put them tougher and low. spend little and .. little enjoy! here I did make an uncompromising kit that would offer maximum performance. Think, I also torsion bars increased, Powerflex Black Series rubbers kits, the limited slip differential ... you bought 2 cars only with these things!
KeithD (03-01-2024)
This is a joke right? I’m pretty sure some people who have the disposable income and want coilovers would consider it.
On the subject, I wish to keep my car until the wheels fall off because of sentimental value. If I ever move to the states after graduating, because of the economical disaster that is Puerto Rico, I will ship the car over and when the time comes I would gladly get these coilovers.
Deuce, does the seller make discounts for group buys? The price is already steep enough, but the product is an attractive proposition. Do you already have these installed? How does the ride quality and handling compare in a setting meant for street use?
User 070620 (07-04-2018)
[Quote = giandanielxk8; 1.921.238]
Questo č uno scherzo, vero? Sono abbastanza sicuro che alcune persone che hanno il reddito disponibile e vogliono i coilovers lo considererebbero.
A proposito, desidero mantenere la mia auto fino a quando le ruote non cadono a causa del valore sentimentale. Se mai mi trasferirň negli Stati Uniti dopo la laurea, a causa del disastro economico che č Puerto Rico, spedirň la macchina e quando arriverŕ il momento riceverň volentieri questi coilover.
Deuce, il venditore fa sconti per gli acquisti di gruppo? Il prezzo č giŕ abbastanza ripido, ma il prodotto č una proposta interessante. Ne hai giŕ installati? Come si confronta la qualitŕ e la maneggevolezza della guida in un ambiente destinato all'uso stradale?[/ Quote]
obviously I installed this kit as NTP-Bilstein ITALIA did it for me.
contact the seller directly for more information. WARNING: I had to send my original top-mount (front and rear) for the correct calibration!
the suspensions are for sporty road use and I have combined them with the "Black Series" rubber kit from Powerflex and with new more big torsion bars. with the series components I do not know exactly how it will behave.
certainly for group purchases I guess the discount will be greater.
say that i have reported the kit (Luca Manni Grosseto ITALY).
to have better access to the rear shock absorber adjustment, I cut part of the spring housing in the rear suspension arm as it will no longer serve. You should still be able to adjust the shock absorbers leaving everything as it is but access is more inconvenient
Deuce, very nice!
Can these be adapted to fit the X308?
I know the rears are physically compatible but the lower end of the front dampers - well the XKR has a different damper seat to the X308.
Does the 15% discount still apply?
Thank you!
I've so far had zero luck getting custom stuff for the X308.
Thank you!
User 070620 (03-21-2019)
Well sorted after market modifications are fine, but the XK8 was designed as a Grand Tourer not a track car.
Price is very high for suspension especially considering other track modifications you’ll need to make to the XK8 if you really want to see what it can do at the limit.
The X100 fundamentally isn't a bad place to start from as a sportier car:
The bodys torsional rigidity is 16,000 Nm/deg, this is higher than a Porsche 993 (13,800) and a McLaren F1. It weighs about 1715 kgs which isn't a lot heavier than an E46 M3 (at 1690 kgs) and its dynamic index and K^2/(a*b) value are quite favourable for a sporty cruiser. The dynamic index is a function of the yaw inertia which is pretty good too with only 51% of its weight over the front wheels.
All it needs is stiffer bushing, decent dampers, perhaps a manual gear box , a torsen LSD and steering with more feedback.
Its a very tempting project, the only reason I haven't pursued it is because I already own an Aston Martin Vantage.
The following 2 users liked this post by Count Iblis:
mchiti1 (09-09-2020),
David, Deuce obviously has the funds and more importantly the passion and drive.
Is that really the case? The torsional rigidity that high? Surely this only applies to the coupes.
User 070620 (12-23-2019)
