NEW! LED fog lights + daytime running lights + turning light for our XK8/XKR 96/06
Thanks rauscs ! I took my cue from exotica like the Ferrari 250GT and Ford Mustang (yes, that would be exotica to me on this side of the world)
The lamps are 6" driving lamps, Ring RL020G
Ring RL020G
I removed the bumper (because my grill was connected to it from the back) and chopped into the plastic crossbar there, and wired it into a relay from the high-beam wire. I like it, the look suits the car.
![Name: WP_20140823_005_zps7522db59.jpg
Size: 74.3 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/155609d1501211778-new-led-fog-lights-daytime-running-lights-turning-light-our-xk8-xkr-96-06-wp_20140823_005_zps7522db59.jpg)
tregonissy (05-06-2015)
Hello FrankSM,
I would like to install as you pack Osram Ledriving.
I know your post is old but I'm trying because, my knowledge is limited to the "electrical" level.
I am a little lost on the following elements:
- There is only one white plug available from the Osram box ledriving.It is indifferently put on the fog lamp socket right or left?
- where did you connect the black/red pomer wires since the battery is at rear?
- where did you installthe blue wire (ignition signal). there is a lot of fuse box/relay... I'm totaly lost!
I would not like to make mistakes and create potential short circuits!
I thank you in advance for your help.
OneLyx
OneLyx
User 070620 (10-15-2019)
BrentGardner
28
04-26-2024 03:08 AM
SingBlueSilver
08-27-2015 02:20 PM
