New Member, First Jag, Big Problems :/ Help Please!
Old 09-03-2009, 01:29 AM
*fill-up*'s Avatar
Default New Member, First Jag, Big Problems :/ Help Please!
Hey guys, this is my first Jaguar, a few of my friends have/had Jaguars so I decided to get one as a daily driver instead of my other car. I have a nice 99 Jaguar XK8, and I just bought it and spent every penny I had on it, I bought it from Tennesee (I live in chicago) and it died on me an hour after driving it! I ended up having to uhaul it back up to chicago (SLOW 10hr drive)
Anyways, it seemed like it wasn't getting fuel, so I replaced the fuel pump (silver thing) and it still does the same problem, cranks but wont start! Like its lacking gas or something.
I ran the computer and checked the codes they are as followed
P1000 and P1230 (for some reason, P1230 showed up twice on my computer)
The 1230 is a fuel pump relay (as I am told) so I moved around all the relays and it still doesnt start
Please if anyone has any advice, please help
Old 09-03-2009, 02:39 AM
Hang on mate, you do know the fuel pump is inside the fuel tank, right?
Old 09-03-2009, 09:56 AM
Robscountach's Avatar
Me thinks he replaced the fuel FILTER, not the pump
Old 09-03-2009, 10:23 AM
That's what I suspected, so I thought I'd ask.
Old 09-03-2009, 11:09 AM
*fill-up*'s Avatar
No no, I replaced the fuel filter and pump, the only thing that I didn't replace is the big blue thing (not sure what it is)
This is a picture of what I replaced, along with the filter
LINK s.ecrater.com/.../95731/4a29bb6ac458e_95731n.jpg
Old 09-03-2009, 11:14 AM
*fill-up*'s Avatar
Also, if anyone has any fuse diagrams for all 4 boxes, if they can please post of email me links to fillup91x@gmail.com, I think I may have a few blown fuses. I just hate seeing this thing sit in my garage, I want to drive it so badly :/
Old 09-03-2009, 11:39 AM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
link didn't work fill-up.
Old 09-03-2009, 11:55 AM
*fill-up*'s Avatar
Old 09-03-2009, 12:28 PM
Hey,
When you ask for diagrams, are you asking for schematics ?
If not, "what fuse does what" is in the manual. If you don't have, i think there's a DL link here on the forum...
Do you know if you're getting fuel pressure and/or spark ?
Old 09-03-2009, 07:54 PM
*fill-up*'s Avatar
Getting spark, and plugs smell like gas, so must be getting gas. I am almost done replacing the plugs, we'll see were that takes me
Old 09-03-2009, 08:30 PM
*fill-up*'s Avatar
Replaced plugs, same problem, still cranks but won't start. Any advice?
Old 09-03-2009, 08:55 PM
OK, I'm seeing no spark since plugs have gas on them. Its an ignition issue and since it doesn't even try, lets me think its ALL of them.
Mmm, what would keep the vehicle from making spark ~ Mr. JagTechOhio ?
Old 09-03-2009, 09:54 PM
*fill-up*'s Avatar
My car is sparking perfectly, that's not the problem. It just wont run.
Here's everything I've done to fix it with no luck (in chronological order)
-Ran Computer code, came up P1000 & P1230 (aka Fuel Pump Relay)
-Replaced relays with aftermarket relays
-Replaced Fuel Pump
-Replaced relays with Jaguar relays from dealership
-Replaced all 8 Spark Plugs
Still isn't starting!?!?!?!
I have not the slightest clue what could be wrong, I mean I bought the car on saturday and drove it an hour and it drove PERFECT, no overheating, no leaks, no nothing! And then it just bogged down on me and the little car computer said "engine stalled" and since then I have not been able to get it to run! It cranks but does not run!
Old 09-03-2009, 10:45 PM
I'd say Crankshaft Sensor, but that'd show an OBD-II Code.
How can you have spark and fuel, but nothing more... Its like your Timing Chain broke...but those just don't usually do that.
Maybe try spraying a little ether (starting fluid) in the intake and see if it 'coughs'... Don't think it'll hurt the MAF, but find out first !
-Replaced Fuel Pump
Old 09-03-2009, 11:22 PM
*fill-up*'s Avatar
I will try that, and Rob do you own a Countach? I own a 94 VT and this Jag is supposed to be my daily driver :/
Old 09-04-2009, 04:10 PM
Wow, a Diablo !
This was going to be a next venture, but prices seem to be creepy up.
Yes, I've owned a Countach (and a Jalpa) in the past. I love my Lambos !
I wish I still had it since the prices on these have almost doubled in the last 10 years, albeit mine did need a clutch ($ 15K I didn't have).
Ya know, A Murceilago Spyder is the dream car, but NEVER be able to afford a used one in my life time... Then again, I said that about the Countach when I was 15 !
Till Then, I just watch Nip/Tuck and dream of Christians.
Old 09-04-2009, 07:24 PM
*fill-up*'s Avatar
I got it for a steal at $60k but it has around 50k but runs like a charm
Old 09-05-2009, 07:54 PM
*fill-up*'s Avatar
Does anybody know what may be wrong with the car? Because I'm about to just give up and sell it! I mean its an amzing looking car but I need a dependible daily driver and I can't get this started
Someone told me possible ECU?
Old 09-05-2009, 08:24 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Check your PM
Old 09-05-2009, 09:11 PM
Well, don't sell it yet !
We know the dealer (or a local Indy) may not the best place to spend your cash, but may be the best place for your diagnosis. They've got ways and if nothing else factory reps.
Hey, could just be a crank sensor !
I'm sure a tow would be less than what you paid to register it...
Quick Reply: New Member, First Jag, Big Problems :/ Help Please!
