New Pedal Position Sensor Connectors
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
So I discovered that the PPS Connector on the wiring harness was damaged on my car while attempting to replace the 'spider' / 'octopus' heater hose. The previous owner (or his mechanic) jury rigged the connector and it works but I was less than impressed. I attempted to purchase a new connector from Jag but electrical parts (connector housings and wiring harnesses) are no longer available for these cars. So I purchased a used housing from a salvage yard but it had some minor damage. These connectors are VERY fragile so I don't expect the used part to hold up very long.
But there is hope. While searching youtube for instructions on how to remove the connector pins I discovered a source for NEW connectors. I just ordered one.
![](https://findpigtails.com/wp-content/uploads/2020/12/FindPigtails-Connector-Y53C4-0002-fsw.jpg)
findpigtails.com
This connector should fit the '97 to '02 XK8s with the 4.0L. Not sure about the newer cars.
Y53C4 | FindPigtails.com
Y53C4 is a 4-pin automotive connector![](https://findpigtails.com/wp-content/uploads/2017/10/cropped-Find-Pigtails-Logo-Favicon-512px-32x32.png)
dibbit (03-03-2021)
But now I have a brand new one! I ordered it Friday morning and received it Monday afternoon. FindPigtails.com shipped it 2 day overnight. No charge for shipping. Great service.
I discovered that the parts were discontinued. That was the point of my post. You can NOW acquire NEW connector housings for these cars without going through a salvage yard and hoping you can get a part that is serviceable. I'm psyched that I can now find NEW connector housings. The salvaged part cost me $50. The new part (including new 10" wire pigtails pre-crimped with new pins) only cost me $80 with 2 day shipping. It's a great service. Given how susceptible old connector housing are to cracking when you remove/install them to fix anything on the car it's great to now have a source for NEW connector housings.
I guess I'm the only one who finds this exceptional.
My guess is that the vast majority of the various electrical connectors that our cars were built with can be sourced from the many aftermarket companies that sell electrical components. The challenge is being able to find the appropriate part numbers and then being able to cross-reference them to something readily available for a reasonable cost....
Just an idea. (I am NOT affiliated with FindPigtails.com nor do I have any financial interest it them. Full disclosure.)
Jon89 (03-05-2021)
I assume the connector is the one on the TB, 4 pin. Mine literally crumbled when working on my 2000. I found the replacement at Ballenger Mortor sports. I did not use a pigtail as the old connector disintegrated and I just pinned the new connector. The connector is made by Sumitomo. The electical system is mostly Nippondenso. Some xk8 connectors are also used on Toyota and Lexus so you may see that as the application.
kstevusa (09-17-2021)
Yes the old conector was so brittle I was able to just crush it and remove the pins and cables with out any damage. If I recal I just used a pair of pliers to break it up. You cannot use a pigtail. you need a fresh unpinned connector. Just remember the pin order.
galearmstrong (01-27-2022)
Thank you for sharing this!
galearmstrong (01-28-2022)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/300x300/conn_100599_2_jpg_thumb_300x300_mat_94612e009f5d2cfec5f1f0307f4d9b5c70fd74d9.jpg)
