New Problem to Dive Into
Hi All,
This is my first post! This site has been a great resource for me since I purchased my "new" 1997 XK8 Conv. I have really enjoyed this car for the short time I've had it, and I have fixed many of the issues that I inherited. I am in a pickle and need some good advice.
And yes, I have searched this site extensively to no avail.
My rear quarter windows have both of their "raise" relays energized. This is the case whether the car is on or off. The conv. top works as it should (with the exception of the rear windows) and there are no warnings indicated on the dash.
Both of the window regulators work as they should when jumped after removing the relay control fuse.
Any ideas?
Any ideas?
I think it is one of two things: Either you have a short to ground as the green-black wire makes its way from the two rear quarter window raise relays to the Body Processor Module (BPM) or the BPM has a fault. The BPM is behind the glovebox.
These are the steps I would take:
1. Try a hard reset. If that does nothing then...
2. Disconnect the battery, then unplug the BPM, then reconnect the battery. If the relays de-energize then the BPM is the likely fault. If the relays do not de-energize....
3. Disconnect the battery and unplug the BPM again. Use an ohmeter to verify the green/black wire from the relays is shorted to ground (it very likely is). Then trace this wire from the back to the front of the car, looking for where the insulation is damaged and shorting to the chassis.
The following 3 users liked this post by WhiteXKR:
wcnesta (06-23-2012)
Received 6,312 Likes
It doesn't always work out for the best though.
![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
Omniparient, welcome to the forum, you may want to post in the intro section, you might find it useful to have full access to the forum if you need to access documents etc.
The troubleshooting procedure from WhiteXKR is the way to go on your problem. If you look at Rev Sam's video on how to raise and lower the quarter windows manually, by adding a toggle switch, it might give you more information about your problem. Maybe the previous owner tried to install the switch and botched it. Good luck on finding your problem, it doesn't sound like it should be to difficult to find. Welcome to the Forum.
Bill N
03 XKR vert
Bill N
03 XKR vert
WhiteXKR (06-23-2012)
Thanks for all of the good advice. I had intended to tackle my current problem this weekend and realized before I did a hard reset that I didn't have a radio code card.
I've had other cars with no code and have called the dealer and have been provided the code with no problem. My last car was a BMW and they gave it to me very fast. I think I already miss the helpful people there.....
So I call the Jaguar dealer and they rudely said that I would not be recieving the code over the phone and that I had to come in to the dealer and have them fetch it for me. I reluctantly made the trip and they insisted on taking my car into the dealership service bay and proceeded to put it on a lift and "inspect" it. After waiting for an hour, a service writer returned with a multi-page printout that had every bit of information about my car except the radio code. It was yesterday (saturday) and he had to call Jaguar NA on monday to get it for me.
He'll be calling on monday with the code.
It's been raining here and I can wait a few days to get my top situation resolved.
That was not a good first dealership experience. I'm gonna check out the dealer in my neighboring town before going back there for sure.
omniparient (06-24-2012)
WinterJag
16
10-09-2015 07:49 PM
