New to the site -question on adding trans fluid
Welcome to the forum.
In the future posts your questions in the XK8/XKR section.
The fluid must be pumped into a port on the side of the transmission following this procedure:
See http://www.jagrepair.com/images/Auto...s%20manual.pdf pages 3-5.
An inexpensive manual fluid transfer pump will do, must you must follow the procedure and do it at the correct temperature and with the correct fluid.
Received 6,330 Likes
Welcome to the forum Brian,
I've moved your post to he tech section.
An intro in the new members section would be appreciated.
https://www.jaguarforums.com/forum/x...uestion-78968/
watch your hands doing this. get a piece of asbestos to cover exhaust pipe when fitting the plug.
https://www.jaguarforums.com/forum/x...y-flush-89780/
chatmanx
09-11-2015 07:17 PM
Wes Steenrod
09-06-2015 06:52 PM
