First time on, just some pics of my 2005 XK8s, which I have just changed the headlining and rear parcel shelf for black in place of the grey, also dyed the sun visors and sprayed the grey plastic around the map lights, not the easiest of jobs, much easier once I took out the passenger seat. This meant I could also get both headrests working using the uTube method of shortening the cable by 12mm, and putting an 8mm pipe connector in, now both work a treat, as well as changing all bulbs to led's, still bits and pieces to do but looking much better now.
I've moved your thread. After being a member for more than four years, this is more appropriate in the XK8/XKR forum than in New Member Area - Intro a MUST forum.
