New window glitch
Kitty (is that what you like to be called?), I have a 98 too. First thought is door switch.
Do puddle lights on that door light properly? (On if door open, off if door shut)
Does drivers door open/ Red light display under Speedo in message center, when ignition on, door open?
The car may think the door is shut, no puddle lights go on, no door open message. These are both connected to the operation of the door switch in the door' s female striker latch.
Let us know the results. It's a common problem and we can help. If I'm wrong, we'll try another test.
John
John
Battery indeed!
Hi,
I had the same problem with my XK8 -04 sedan.
Battery was only half charged due to me only driving 10 km to work.
After being fully charged, both windows lower slightly when doors are opened and raise fully when doors are closed.
Remember to reset the bottom-top positions for the windows by lowering, hold the button and wait for the click-sound.
Do the same procedure when raising the window.
The following 3 users liked this post by jelu02:
Kitty Paws (01-20-2018)
99xk8guy
06-05-2023 06:28 AM
oldtrojanrunner
03-25-2014 08:35 PM
david i
04-02-2012 04:11 AM
