New Window Grimlin
Just when I thought I had all the Grimlins out of my 03 a window issue popped up yesterday:
The drivers window, when putting the top up using either the door key switch or the remote top control, does not act correctly. I have tried, several times, a hard reset with the battery and reprogrammed the windows but still have the issue.
Here's the details:
Using the inside console switch everything works correctly but with the inside console switch the windows do not automatically go up anyway.
Using the door key switch or the remote top control results in the same issue so I do not believe it's an issue with the remote top installation.
When putting the top down everything works correctly
When putting the top up the passenger side window goes up, drops again 1/2 inch as it should however I can see the drivers side window start to go up but it stops as soon as it barely protrudes from the door, when the top cycle completes the passenger windows goes back up to seal and the rear windows go up but the drivers window just goes up the 1/2 inch to seal. So the result is the drivers window only has raised about 1 inch out of the door.
If I put the drivers window up before putting the top up with the remote or key switch it acts correctly, drops 1/2 inch, top cycles and it goes up to seal.
Any suggestions, as the window does respond just not correctly I fear the control mod is bad.
Here's the details:
Thanks for the reply however I already did this. Have tested everything several times running and not running with the same results. Reset window at least 8 times, did hard reset by touching neg to pos on battery two times. No change in results.
Only thing left now is to swap window mods and see if the problem follows unless someone has a better idea.
OK what I don't think was clear from your post is you are doing the top mod, I'm assuming with the module you got from Jag Wrangler. If that is the case I'd call him up as he likely has run into this before. If the car was working fine before you put the mod in and you didn't fry something taking the mod out should restore the car. If taking the mod out doesn't restore the car you likely have to replace one of the control modules. But give the guy that sold you the mod a call first as he'd have the most experience with it and should be able to help you get this all sorted.
Received 6,332 Likes
Yes I have the top mod but it has been installed for a month with no issues. The problem is identical regardless of if I am using the key in the door or the remote thru the top mod from Steve so the top mod is not the issue as it just mimicks the way the key in the door works. Thanks but you guys are on the wrong track and I indicated several times in my first post that the issue is the same regardless of using the remote or the key and said nothing about tring to install the top mod. I will send Steve an email just to confirm however I see no way Steve's top mod could cause this issue.
I do however appreciate the replies and assistance in resolving my problem.
Here's the details:
Here's the details:
Jamdmyers, mine works the same as yours when using the inside control switch.
The issue is the drivers door only window is not acting correctly when raising the top from outside the car. If the window is down when the top cycle starts it does not respond correctly as indicated in my first post.
Steve, yes I have done the hard reset twice with no results.
philwarner
28
07-11-2017 10:21 AM
blackenedindustries
09-30-2015 10:17 AM
