New XK8 Owner Key Fob Question?
Hello everybody!
I recently picked up for a steal, a 1997 XK8, 80K on the odometer, almost pristine condition, very well maintained. Just a couple of little problems -
1) It's missing the key fod/remote, just two regular keys. I've seen replacement remotes on ebay, but how do I programme them? is it something I have to have a dealer do?
2) The antenna does not extend, is there a particular fuse I should check or, should I just purchase a new one.
and finally,
3) Stuck in traffic on a very hot Texas day, I had a temperature spike, all the way into the red zone, fortunatly I was able to get off the freeway and shut it down. 15 minutes later in the shade, started it up, it spiked again but within seconds it returned to normal. Got it home, fluid level was low but by no means critical.
Since them I've had no problems with it, driving it progessivly further distances and in all traffic conditions.
So, sticky thermostat? Air bubble? Low fluid? Water pump? Radiator?
I'd appreciate any suggestions.
Thanks!
and finally,
Thanks!
Welcome to the forum. You should visit the new members section and introduce yourself. You will have to wait until you have 10 posts and a couple of weeks since joining before you can access the wealth of information in the sticky's.
I don't have a fob yet, can't help. The fuse is, I believe #9 in the box under the luggage area.
Your thermostat should probably be replaced, as well as the water pump, and a aluminum thermostat housing if not done by PO.
Have the secondary chain tensioners been upgraded? Very important.
RJ___________
97XK8 Conv. 85K mi
RJ___________
97XK8 Conv. 85K mi
Drove for a while longer and it happened again, the same way. Shut the car off, then switched back into position 2 and the gauge was reading normal again. Restarted and continued on.
When I got home (AZ) I cleaned the temperature sending unit connector with electrical contact cleaner and haven't had a problem since.
This problem occurred while driving across Texas, same as you, so maybe there is something in the air.
Welcome to the forum RadioHack,
As RJ237 says, we must have missed your Intro. Catch up when you get a chance.
1. your XK8 will have been supplied with 2 x Black headed keys (master), 1 x Green Headed key (valet) and 2 x Remote Fobs. YES you can get them on eBay and YES you can program them yourself without a visit to the dealer BUT you must get the right fobs with the right frequency. US members will be able to provide details.
2. the antenna fuse is in the luggage compartment fusebox. You'll find the fuse number in the Vehicle Handbook. Antennae regularly stick but check the power feed first before buying a replacement.
3. ccfulton reckons this is 'Texas Temperature Syndrome'. The descriptions sound very similar but be aware sticking thermostats are a known issue on the V8's.
threemano (08-20-2012)
Received 6,320 Likes
I call Lucas on that one.
But the advice about thermostats is well taken. These engines do not like getting hot at all and the temperature gauge is a placebo. A thermostat is a cheap and easy to do maintenance item and well worth it.
It was the instant "cooling off" that told me the over heating wasn't real. Physics says that switching the car off and back on over the course of a few seconds should not make the temperature change in an appreciable way.
I would venture to say that your temp senosr connector fault was the exception. The thermostat can cause the same symptoms, and is a much more common fault.
The temperature increase I can understand coming on very quickly with a sticky thermostat but the cooling down I am having somewhat more trouble with.
I won't say it can't manifest that way, and I'm not trying to be a jerk about it but I'm not quite seeing how it would. For that to happen you would have to very abruptly exchange a slug of hot water with cooler water and then again for hot water and I just wouldn't expect a thermostat to fail that way. Slow, yes. Sticky, yes. Binary back and forth, I'm skeptical.
Don't take me the wrong way, I replaced the thermostat too, better safe than sorry.
No argument with the physics Charlie.
I just spent a fair amount of the time simulating the coolant sensor inputs while developing RealGauge, and though I did not formally document it, I did see some curiously highly non-linear behavior around the trigger region between overheat and normal with the instrument cluster computer driving the gauge.
You learn something ever day.
See OP item (1)
I think we're agreed the temperature gauge as originally configured by Jaguar is misleading and useless?
It might as well be:
I wasn't dismissing a faulty sender as the most likely cause in this instance but mentioned thermometer because the OP RadioHack is a new owner living in a hot climate and may not be aware of this well known issue.
