Newbie
Newbie
Need some help on how to fix the lights on the center console switiches. The rear fog lamp switch and a couple of others don't come on. Any ideas also need some help with the internal and external temp sensors so i can have the climate control working. regular air con works perfectly. Thanks people
Newbie
Hi thanks for the faster than light reply, will check the error logs shortly, the trouble with the switches is that the night time lights do not come on otherwise they seem to work fine. Now here is a stupid question, how far do the front seats recline both of mine seem to recline back a bit than stop??? Thanks again
Charlie Galea (08-11-2012)
Thanks white will start on switches as soon as i find out if the bulbs are available here, the recliners work both forward and backwards but do not go al the way back, just want to know if thats the way Jag made them. Now seem to have an other small problem, the door windows do not go back up when i close the door, they used to go back up that one inch to lock back up into the roof packing. every time i open the door the window comes down an inch and does no go back up when i close it. I will check and post by other members if they had this problem. Thanks again
Charlie Galea (08-12-2012)
Marka
22
09-11-2016 12:09 AM
