Nikasil What is it and How to Identify it! FAQ
Old 07-11-2011, 12:53 PM
mike mitchell's Avatar
do i have to sell my 97 xk8? my usual driving day consists of a one mile drive to breakfast every morning. this could explain all the problems that are getting worked on now. is it okay to only drive a mile, as long as the temp guage is in the middle? not willing to drive around wasting gas just to warm up.
  #42
Old 07-11-2011, 05:44 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Read this and see if it helps you understand the situation Auto Repair I could answer by saying if the engine gets to the operating temperature, but that may not be correct. I could say fuel presentation is the key, I could say anything you want to hear but the bottom line is all the above. Read my information and then ask me your questions and I will try to help.
  #43
Old 05-18-2023, 03:05 PM
Ashby90's Avatar
Default Nikasil engine I’m confused!!
So after some research I know that the Aj26 engine has the Nikasil engine but what about the AJ26s engines?
engine number is PB0105211701
code is AJ26s
vin ends in PA23036
i have the 2001 model and I know the Nikasil is an issue pre 2000 but is the AJ26s engine just one off the shelf they have put in a 2001 model car
  #44
Old 05-18-2023, 06:00 PM
michaelh's Avatar
Received 2,390 Likes on 1,550 Posts
No AJ26 left the factory with steel liners. I guess by AJ26s you mean the supercharged version?
Engine # PB0105211701 indicates a 21st of May 2001 build, hence will be an AJ27 with steel liners (and plastic tensioners if original)
VIN ...A23036 car built June/July 2001.
ricwel
06-23-2023 05:14 PM
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
sawduster
09-11-2015 10:02 PM
Quick Reply: Nikasil What is it and How to Identify it! FAQ
