no acs, no trac, and abs
Did you wash the car or did a bug or mud get into the wheel sensors? I would suggest cleaning your wheel sensors and the electrical connections associated with it first. It could be your ABS module but would the other checks first. This link should help Front Brakes on 2001 XKR - Jaguar Forums - Jaguar Enthusiasts Forum
If the fault reappears, there's a lot of info tied in with when -- under what conditions -- it happens.
If you get the warning before the car moves, or more precisely moves at faster than a few MPH, that's not dirty sensors.
I like this test: after starting the car, turn the steering wheel lock-to-lock a couple of times. If you get the warning, the fault is almost certainly in the wiring or connectors to the front wheel sensors. This happens a lot and is cheap and easy to fix.
Good luck.
Good luck.
tomtomterrific (06-04-2011)
goges
10-05-2015 04:53 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
