No cats on Cat, is it possible?
So, I recently found out that my little island paradise here has no regulations regarding the presence of catalytic converters in cars. Apparently they can be removed and no one will bat an eye when it comes time to inspect the car.
So I was wondering, is it possible? Are there any benefits? Do they outweigh the environmental impact?
The guy who told me this, said that as long as the car doesn't have O2 sensors after the cats, that it should be possible.
I plan on eventually upgrading my exhaust, so I might take this in consideration.
I wouldn't remove them. There seems to be no benefit to doing so.
I follow the Corvette forums religiously and those fanatics are addicted to HP and there doesn't seem to be more than MAYBE a 5 hp gain as confirmed by numerous dyno charts. Sometimes not even 5 HP.
Modern catalytic converters are well designed and I wouldn't mess w them.
JMHO
JMHO
One of the biggest restrictions is the cats, however these engines do like a certain amount of back pressure and by free flowing the engine too much you loose power in the lower rev range but gain it in the higher....
Yes you will show more than 5hp but you will be doing 3000 revs to show it and over 100 mph so you will not gain any advantage, on my track car I have a manual box and can hold the revs as high as I like so can take advantage, keeping the lower cell cats would be better than none at all in a road car
No I would not say that, but I would say try not to go over board, if you had 200 cell cats with hardly any exhaust boxes you would have quite a free flow system, you would gain more power towards the top end but lose it at the bottom, and lets face it low down power is much more applicable for every day use
Received 2,190 Likes
No cats, no mufflers after the axle. I still have the factory resonator
https://plus.google.com/u/0/photos/y...58934572899632
http://www.newchallengerstore.com/Ch...ce_Exhaust.htm
