No clicking and no dinging sounds
The blinkers all work including the ones on the dash but the relay no longer makes the clicking noise when the turn signal switch is operated.
The other audio fail is that I believe I used to hear dinging when I first turned the key and it was running through the systems check. I have a feeling there is a link here between both things, Any suggestions would be appreciated, is there maybe a common fuse?
Alan
Alan
The following 2 users liked this post by hnh375:
alanroberts50 (08-05-2020),
DavidYau (08-04-2020)
The following 2 users liked this post by motorcarman:
avern1 (08-04-2020)
[/size]
Hmmmm so I ordered the part. Driving down the freeway the blinker tick tock started working again and then when I stopped to let my friend out all the other warning sounds worked momentarily As they should and then all failed again. In my experience if a speaker fails it doesn’t really come back so could this be something else? Maybe when I used the ignition key to start the car something got disturbed? Dry joint I suppose is possible. I will replace the speaker now that I bought it and report back.
Update
So the issue is still intermittent however now when I lose the audible warnings powered by the steering column speaker I also lose the backup sensor audible warning which could be dangerous. I think I’m correct that the backup sensor warning is a different speaker. Is there a common connector with these two systems that I could check?
I found a direct fit replacement on ebay and installed it in the steering column today. The size is 66mm. 64 Ohm. .5watts.
https://www.ebay.com/itm/AIC-GF0661M...53.m2749.l2649
