no communication
I get a no communication signal when I hook up a scanner/reader. It also tells me to make sure the key is on (even when the key is on or car is running). I have used different brands with the same result. What might cause a no communication situation? Bad Plug/pin connection upon ECM reinstall?
Car runs fine and has no engine codes displayed.
(Note: Air control valve was replaced and ECM rebuilt before I bought it.)
I have basic tools at the house and no tech manual for the car.
I'm gonna be out of service for a couple of days, so Ileft itwith a friend and he's gonna check the wiring, chase electrical, and see if he can get it to communicate.
I'll update all, when I'm up and running again.
Thanks.
Thanks.
I'm back.
Update:
All campaigns (for 97starting problems)checked out O.K.
Checked all parts the campaigns said to check.
Forced problems and still did not throw any codes/lights.
Gonna talk to a dealer aboutECM reflashwith ECM in car. (TSB 1102)
(Couple hour process where they put a charger on the battery to keep car in proper voltage range while reflash of ECM is in progress)
(From what I understand, it's like putting windows on your computer after you replace your hard drive)
Any of this make sense. If so, how much will I be paying?
Update:
Have paperwork from dealer (non-jag) that said ECM repaired in Nov 07.
Any ECM repair guy around San Antonio, Tx.?
It might have been bad repair job.
Repair was done to ECM out of veh.
Question: 97 XK8 ECM is CAN plus but what program? I heard there are 14 variations for CAN plus that year. (VIN VC003032)
I bought the car from ahigh volume car dealer (more like used car lot)outside houston. No warranty. As is.
That's probably why the cars are priced so low. Buyer beware.
I'll let you know this week what local Jag dealer comes up with.
If they say bad ECM, then I'll try to get a hold of the sublet shop that the Houston dealer used and see if they will make it good.
I need to figure out the "no communication" problem first before I go on to possible cylinder wash.
Note: I am begining to be quite knowledgable on 97's.
Dealer finally looked at it.
They said no communication problem, their genrad ? scanner found about a half dozen codes.
I'm gonna get it back Monday morning.
They printed a list of the codes for me and I told them to clear them out so that I can see if any fresh codes will appear.
Dealer seems to think it is an ECU problem, but ECU was just rebuilt (maybe bad rebuild job ?)
Dealer just called and said codes cleared and no new codes appeared. He said drive it a while and bring it back for a check up.
*** possible that codes were not cleared by former owner after ECM rebuild.
