No electrical at passenger door
Hi all, this morning, when started the car, showed for the first time the "passenger door open" message. Checked the door and it was well closed. While continuing checking, the power window on that side didn't work, neither the power lock and power mirror. Seems that anything electrical isn't functioning at the passenger's door. Driver's door is OK, top and rear quarter windows on both sides working OK, any other electrical function in the car is OK. Any ideas where to start checking? Thanks.
Felipe Pr (02-13-2012)
If that does not fix it, it sounds like either the pass. door module is not getting power, or it has failed.
Felipe Pr;
You may also want to check #4 fuse (5amp) on the passenger side fuse box. It splits and is the fuse link protecting the passenger door lock switch and the power door lock control in the passenger door control module. It also protects the door window switch for the power window, passenger side.
I'm suggesting this since you stated you were getting "passenger door open" message.
Also, is the puddle light in the passenger door operating? This may be an indication the passenger door module is properly functioning since the light also goes through the passenger door control module.
Where is the pass. door module, how can I check it. Aren't any relays to check first?
Felipe Pr;
Had a similar problem on the driver side, fuses were all ok. Ended up being the door module. You can get to the passenger side door module which is located behind the door speaker. You should be able to remove speaker cover that will pop out after you have removed the two screws on the underside of the speaker cover. Remove screws holding speaker and the rubber foam speaker cushioning. The door module is in there, its a gray box. I bought one from ebay for around $100, installed and problem solved. Good luck.
The door module operates off of battery power directly (no relays) since it must operate with the ignition off.
First, I like to thanks XK Racer, White XKR, Jag13 cat and Mr. CJ, All of you gave me great input into diagnosing the problem I have. After discarding many options, it seems now that the problem is the door module. This afternoon I removed the door module, a task that is a PITA due to how difficult it is. It is located above the stereo speaker in a very narrow space. The door panel and the speaker has to be removed (Mr. CJ, mine is a 97, yours is a 98 maybe your's is located behind the speaker but mine is way over it, attached with three bolts inside the door frame, there is no way to access it without the removal of the door panel).
Checking Ebay, I found a used one for $100 from a 97. My concern is, been a used one from a 15 year old car like mine, how long it will last. May be better to bite the bullet and buy it new, what's your opinion? How common is to these modules to fail?
You never know with electronics. You might check to see if any kind of warranty is provided. I would suspect that the module is quite expensive new. I get a lot of my parts from 707 auto parts. They have always been honest, and I know they offer warranties. I just spoke with them today about some parts that they are sending my way. I know they have plenty of door modules available. Good luck.
As far as location, my door module was just hanging inside the door frame behind the speaker, maybe someone messed with it prior to my ownership, so it could possibly have a place to be properly mounted. Anyways, I installed the new one and it fixed my problem, so I was happy. Good luck to you.
Felipe Pr (02-14-2012)
I am a bit late coming back in on this one!!!.... My next suggestion would be the door module and like GUS has said (if you can be asked) is to swap it with the other side to make sure, they are not as common as seat modules to pack up but it is known.
I do have one in stock which I will sell to you for $100 delivered, all modules are located in the same place for all yesrs X100. Good luck
Originally Posted by Gus - If it was not such a PITA I would suggest swapping it with the other side to be sure…
Originally posted by H20boy - What was the condition of the one you removed? Did it appear to have water damage or anything? Physically, is the cover cracked, broken?
Originally posted by XKRacer - I am a bit late coming back in on this one!!!.... My next suggestion would be the door module and like GUS has said (if you can be asked) is to swap it with the other side to make sure, they are not as common as seat modules to pack up but it is known.
![Icon Dance Tap](https://www.jaguarforums.com/forum/images/smilies/icon_dance-tap.gif)
![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
Tomorrow morning will wash it and give some TLC and after that will take a good ride with the top down. Forecast is sunny, mid 80's, maybe will go to the beach for a couple of hours with my lady, have a couple of
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
