No Heat
You can check climate fault codes from the front panel. See attachment.
Also check the coolant pump fuse, #15 in the engine compartment fusebox.
While you are in the fusebox, make sure none of the relays have worked loose from their sockets.
After a period of non-use, the most likely cause is a stuck heater valve, or possibly a bad coolant pump.
berlin1977 (10-05-2012)
berlin1977 (10-06-2012)
