No oil pressure for 6 or 7 seconds after cold start up
I have a 97 XK8 with 120,000 miles. I replaced the tensioners as a matter of preventative maintenance about a year ago. However, the other day when I started up, the message center displayed low oil pressure and it took several seconds for the pressure to come up. Normally it comes up immediately. Coupled with the long oil pressurization was a clattery sound from the front of the motor apparently coming from the front left cam cover, or so it sounded. I removed the cam cover, but there is nothing obviously wrong. Could this be a tensioner failure? If so, what would be the oil pressure delay? And what would the failure look like?
Any ideas anyone??
Les
97 xk8
Any ideas anyone??
Les
97 xk8
You can replace the low oil pressure switch near the oil filter...it is easy to do and inexpensive BUT another common cause is bits of plastic debris from the timing chain tensioners and guides that have accumulated in the oil sump.
Since you have already upgraded your chain tensioners, then just drop the oil pan and inspect and clean the sump of debris.
Issue can also be with the oil pump, or a worn engine, but it is less likely that the above.
Note that the gauge is actually fake and just has two positions: no pressure and pressure over about 6 PSI which reads center scale.
(Also, be sure you are using the factory recommended oil viscosity.)
Les
Thanks for your help.
Les
