no power to antenna
I think that there are two power feeds to the antenna - one through fuse #9 which supplies power to the antenna motor, and a second which comes from the head unit which, I think, energises a circuit with a relay (or two ?) inside the antenna to switch the motor on & off and up & down. This is a green / black wire. If it doesn't work with two antennae - would be worth checking that you have 12volts on this wire too (when the head unit is switched on obviously)
There is also a ground / earth connection which would be worth checking - might have vibrated loose ?
Looks like there should be three wires :
1. Brown / Green = 12v + from fuse box.
2. Green / Black = 12v+ from head unit.
3. Black - ground (probably a short wire to a ground stud close to the antenna)
1. must be "always live" - otherwise the antenna wouldn't retract when the ignition was switched off and the key removed because the motor needs power to do that.
