No start after replacing battery
Easy to put the battery in backwards and fries the alternator voltage regulator . I think charging cables reversed will do the same . Been there , and a garage will sometimes as well . Had a part for the X308 voltge reg on Ebay as the rest of the alternator should be OK . It will blow a couple of other fuses so you'll have to pull all of them and inspect one at a time .
Is there a fuse map for the X308 that someone can post ?
I have to make assumptions because there is absolutely nothing in your forum profile other than the fact you are somewhere in the US.
1. Make - has to be a Jaguar
2. Model - high probability it's XK8 or XKR
3. Year - no idea
4. Jump start - sudden dead battery on an otherwise reliable vehicle or some history of issues that could be relevant?
It's very easy to fry sensitive electronic components on these vehicles if they are jump started the wrong way. It's all in the details .......
Disconnect the battery cables from the battery and use a VOM and measure battery voltage at the terminals. You should have between 12.5 and 13.5 volts. Anything lower and the battery is BAD.
If you have 12.5 to 13.5 volts the clean and polish the posts and the cable ends. You have a high resistance connection.
Since the vehicle will start with cables connected to the outside of the terminals it is either battery or connections.
This is a link to the fuse map on page 208 . I don't know what year this is for ( looks like for 2012 ) but Avern1 listed some differences :
But then I mixed up the X100 for the X308 .
https://www.jaguar.nl/Images/XK_Owne...m141-26491.pdf
![Icon Screwy](https://www.jaguarforums.com/forum/images/smilies/icon_screwy.gif)
Lady Penelope (04-07-2018)
Received 1,442 Likes
+1 to post #2 from JagV8 . . . but with total lack of info from OP, followed by total lack of feedback from OP . . . heck it could be anything from any of the other guesses so far, right through to "pop the bonnet/hood and check no-one has swiped the engine".
Not helpful? Well, nor is a request for help from a shop that should know enough about these cars to at least provide relevant data.
Ken
Ken
Thismethatyou
05-15-2017 09:27 AM
awmotors
XJ40 ( XJ81 )
46
03-18-2010 10:43 AM
