No Start/ Sport mode button?
Battery test
Before charging; 12.40v. After charging 12.40v. At idle 12.60v. battery info;Autocraft Gold, part # 49H8 ,cranking amps 950, cold cranking amps 760, reserve cap. 160. Dated 5/11. I'm not seeing anything that would point to the battery. i'll be driving it every day for this week, and as I previously said it will start in neutral when it does this. Your thoughts? Thanks.
I would always start in “P” and when It does not start then try it in “N”. The theory is if it does not in “P” and it does in “N” then you should look at the adjustment then replacement..
Link http://www.jagrepair.com/images/TSB/307-01-1.pdf
Bob OB (06-10-2013)
