No Start/ Sport mode button?
Old 06-09-2013, 11:42 PM
plums's Avatar
Received 2,181 Likes on 1,621 Posts
Once it has charged, hook it up, leave trunk open for 15 minute. Measure voltage across the terminals and report the reading to two decimal points. Also, the brand and model of battery.
Bob OB (06-10-2013)
Old 06-10-2013, 12:18 PM
Bob OB's Avatar
Default Battery test
Before charging; 12.40v. After charging 12.40v. At idle 12.60v. battery info;Autocraft Gold, part # 49H8 ,cranking amps 950, cold cranking amps 760, reserve cap. 160. Dated 5/11. I'm not seeing anything that would point to the battery. i'll be driving it every day for this week, and as I previously said it will start in neutral when it does this. Your thoughts? Thanks.
Old 06-10-2013, 06:13 PM
Gus's Avatar
Gus
Gus is offline
Received 2,212 Likes on 1,702 Posts
I would always start in “P” and when It does not start then try it in “N”. The theory is if it does not in “P” and it does in “N” then you should look at the adjustment then replacement..
Link http://www.jagrepair.com/images/TSB/307-01-1.pdf
Bob OB (06-10-2013)
FtypeRRR
09-26-2015 05:46 PM
Jagged-X
09-24-2015 05:08 PM
Steve10
09-20-2015 12:27 PM
reb1999
09-19-2015 07:30 AM
Quick Reply: No Start/ Sport mode button?
