No vacuum through PCV valve?
Old 03-21-2012, 12:46 PM
dx3's Avatar
dx3
dx3 is offline
Default No vacuum through PCV valve?
Guys,
Started troubleshooting my engine woes last night (rough idle, stumbling, no power). I pulled the PCV valve hose and plugged it. Started the car and let it run for a little while, then removed the plug in PCV hose expecting car to stumble and die. Nope, made no difference when I removed the plug. Was trying to think of reasons why it wouldn't have affected it and why I was feeling no real vacuum?
Could a bad vacuum leak somewhere be the issue? Any thoughts or ideas?
MAF seemed clean, clean air filter, plugs look ok, coils look ok. Next step is compression test.
I can hear what sounds like a huge vacuum leak but was unable to find it. Didn't have incense or anything to try to blow smoke last night but will pick some up too...
Thoughts/ideas/suggestions.
Thanks,
Jonny
Old 03-21-2012, 01:11 PM
H20boy's Avatar
Received 1,150 Likes on 753 Posts
many small leaks can add up to one big one too can't remember what people use to spray around their engines to find a leak, something combustible I think!
Old 03-22-2012, 08:16 AM
barryl's Avatar
Yep,
spray something combustible in short bursts in a defined pattern and when it gets near the leak the engine will increase RPM. Some have used WD-40 but I am sure there are better products for this test maybe starting fluid but that might be a little too flammable
Old 03-22-2012, 10:12 AM
randyb's Avatar
Soapy water works great on cold engines and throttle body spray works well, but it might not be a leak. Hoses near really hot areas haven been known to get soft while hot and collapse on it's self.
richard bowles
06-10-2023 12:24 AM
tomkilner
10-09-2015 07:10 AM
Johncy2000
10-02-2015 01:05 AM
thedugger1
09-26-2015 10:27 PM
Quick Reply: No vacuum through PCV valve?
