noise in fuel tank - XK8
I replaced the fuel pump on my 2001 XK8 and now i have a rattling noise coming from inside the tank. If you unplug the pump relay when ideling, the noise stops instantly. (the engine will run for a few seconds after relay is removed) There was a small 2" square plastic with holes in it under the pump screen filter. It may have been knocked out of place. Has anyone seen this problem?
Welcome to the forum choctawman,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to offer further advice.
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
