Noises I Really Do Not Like!
Hey Lads,
So as I was driving around yesterday I began to hear engine noises that put a lump in my throat.
From before and like many XK8 owners, a lot of us experience some chatter after initial startup for a couple of seconds. I was told by most that this was a normal thing for the older cars and many guys are trying oil changes and other things to calm it down. The theory is that it is the VVT system losing oil pressure when the car sits and with my car, that also seemed to be the case. I was made aware that problems with cam chains, tensioners, etc were only on pre 2003 cars and my car is a 2003.
So I am pulling onto my street and I hear a kind of clattering noise from the engine at anything above idle. It would also do it if I turned the steering wheel harder left or right which is kinda weird. I don't even know where to begin to look into this. I guess I have to start the car again and discover what the heck is going on here but I can say that I am hesitant about even doing that. It was definitely a clattering sound from the engine area and it sounded like it could be a loose cam-chain for sure. At idle it was quiet but that could also be normal for a loose cam chain
So I had already planned to tear the front end down anyway to investigate the VVT system. I have a small leak from one of my cam covers anyway so it was to be a part of the larger "front of engine" project.
Anyone else ever experience the same symptoms?
I know this is leading to tearing the front of the engine down regardless but just trying to collect some knowledge prior to digging in
My XJR has 95k and my XKR has 105k. I've replaced all 4 idler/tensioner idler bearings on both cars. The bearings are super cheap and easy to do. I've also had to do a supercharger rebuild on my XJR, water pumps on both cars, and the PS pump on the XKR.
Check all belt drive accessories and if you have no glaring errors, consider starting the car beltless to diagnose if the sound is indeed NOT the belt drive.
At one point my XKR's PS pump was making weird noises because somehow the bolts were kind of loose on the pulley. I remember a TSB about that issue. Either way, get checking some stuff methodically .
Earlier this year I convinced myself that I'd got a noise that was engine related , possibly con rods, and definitely from the top end. Turned out to be one of the cats was rattling. Be certain where it is coming from before you start to fix it otherwise it will cost a fortune all for nothing
I have 2 videos on this link for noise that is caused by the belt tensioner. See if it the same noise.
To check your VVT with the engine at idle place your hand on one of the VVT and rev the engine just a little for a moment. When you do that you will feel and hear the VVT click (adjust) then do it to the other side and see what you come up with.
Orthodixie (09-09-2017)
