Non-Mechanic tensioner identification
Old 05-13-2015 | 02:33 PM
xk8lattmaster's Avatar
Default Non-Mechanic tensioner identification
How can I tell if my tensioners have been replaced.
I now have 86001 miles on my 2001 XK8.
Is there any tell tale signs ?
Thanks in advance for your help
Old 05-13-2015 | 04:25 PM
test point's Avatar
Your car originally came with the plastic tensioners and without clear documentation of replacement with the metal version your only choice is to remove a valve cover for a physical inspection. I said 'a valve cover' but there have been reports of repairs consisting of replacement of only one tensioner so the safe decision is to inspect both sides.
xk8lattmaster (05-14-2015)
Old 05-13-2015 | 07:15 PM
motorcarman's Avatar
Pull the $##!^&*** cam cover off and use your 'peepers'!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bob gauff
xjay8 (06-07-2015)
Old 05-14-2015 | 07:04 AM
Dear Bob,
Thanks for the advise, but what is a $##!^&*** cam cover ?
Old 05-14-2015 | 07:31 AM
I think $##!^ is Texan for left and &*** is right.
Old 05-14-2015 | 08:18 AM
dibbit's Avatar
bob gauff
Unfortunately it's not as easy as just "pull the $##!^&*** cam cover off". You have to have the right tools to do it, including a socket set with a universal joint, extensions and, on my XKR at least, a suitable deep socket to get the cam cover bolts with the thread extensions.
Once it is all off it has to go back together with new gaskets, a dab of sealant and you need a suitable torque wrench which goes down to 10nm. I had to buy quite a few tools " just" to do this job and I do lots of stuff to my cars and boat.
Best advice for a non-mechanic is take it to a Jaguar specialist or invest in the time and tools to do it yourself.
This is what the old style tensioner looks like:
Taken from my 2001 45k miles XKR.
Old 05-14-2015 | 08:38 AM
batroute's Avatar
He'll figure it out on his own by using the same language when he does the job himself.
xjay8 (06-07-2015)
Old 05-14-2015 | 09:11 AM
dibbit's Avatar
Yes, when the plastic snap connectors do in fact snap off.
mikiep
12-20-2019 07:37 PM
Jässe in Pälkäne
10-02-2015 05:38 AM
millertic
09-30-2015 08:11 PM
JAMES1944
09-29-2015 11:58 AM
Quick Reply: Non-Mechanic tensioner identification
