Non-OEM filters and startup clatter
So I've heard it said a few times that if you go to jiffy lube they will put on a filter that doesn't have a little valve/bypass in it. Are the OEM filters actually different? I ordered one on eBay for 22$ and haven't put it in yet. I've got at least another 2000 miles on the oil that's in there now.
I changed my sec. tensioners a while back but the is a little noise on startup. Will this new OEM filter make a difference?
It can't hurt. I only use OEM filters just for that reason. $22 vs. ~$15 for the aftermarket? $7 is a very cheap bit of insurance against thousands of dollars worth of engine work (or replacement).
Many forum members use the OEM equivalents (Mann?), just make sure it has the check valve.
If the rattle lasts more than 3 or 4 seconds, it bears checking out. Could be a bigger issue. Are the primary tensioners original? Usually not an issue, but they do begin to rattle before they go, unlike the secondary tensioners which just go out with no warning.
Received 10,952 Likes
Those interested in researching the finer points of oil filters might wanna take a peek at the "Baldwin" brand. I came across Baldwin filters quite by accident. They're apparently have a great reputation.
I ordered some (for a non-Jaguar application) and, FWIW, they seem to be very stout and heavy....which might be totally insignificant. OTOH it might suggest more filtering media inside.
Anyhow, just thought I'd throw it out there.....
Chuck Schexnayder
33
10-24-2015 10:20 PM
